Filling up with gas problem?
i did a quick search, nothing to speak of, so i figured i would ask.
i have a 2007 Enthusiast and can't fill the tank without problems. at first i thought it was the station i was at, but it happens everywhere! when i am filling up, it will stop around 8-10 gallons in. gas even spills out, but the tank isn't full according to the gauge. at first i thought it was the gauge, but when i realized it wasn't i am worried. wtf is going on? is there a pressure buildup or something? if i mess around long enough with it, it will start pumping again and fill the rest of the way............wtf?
jim
jim
Been discussed to death....
https://my350z.com/forum/2003-2009-nissan-350z/24770-anyone-else-have-trouble-filling-up-with-gas.html
https://my350z.com/forum/2003-2009-nissan-350z/244386-empty-gas-tank-fills-to-15-gallons.html
https://my350z.com/forum/2003-2009-nissan-350z/208842-erroneous-gas-gage.html
https://my350z.com/forum/350z-roadster/204731-gas-tank-hard-to-fill.html
https://my350z.com/forum/2003-2009-nissan-350z/194133-gas-tank-not-filling-up.html
Search really does work.
Why is history so doomed to repeat itself in this forum?
http://www.nissanhelp.com/Ownership/.../NTB05-048.htm
P.S...DaveZ..as a mod are you not allowed to link outside the forum..just wondering why you're beating around the bush?
Originally Posted by illjim69
dang! i must type in the wrong stuff when i search.
i typed in "gas filling up problem" and nada......
i am t3h suX0r!
jim
i am t3h suX0r!
jim
i am t3h suX0r!
jim
i am t3h suX0r!
jim
I share your frustration when searching on this Forum. I write database and SQL software solutions, and I don't like the way this Forum handles searching. The software here does not handle intersections, exclusions, conditionals, etc.) In fact the search functions here are very weak. And... when someone diligently does a search and receives little or no results, and then starts a thread or asks a question, they get "hammered" by the "regulars."
Another very aggravating fault in this Forum's search engine is its inability to compare "close matches." For example Farenheit (a popular search term on this forum for a company that intentionally misspells the name) fails if you spell it correctly (Fahrenheit). Same goes for Power Acoustik (should be Power Acoustic, but "Acoustic" does not yield search results).
--Spike
^^^Yeah, what he said.
Thanks for clarifying.
Linking outside is not a problem, we do it regularly. I just don't keep track of all the TSBs and forgot that this is one of them. Thanks for reminding me.
I have an '07 with the same problems filling up"TSB05048 - 2003-2005 NISSAN 350Z; FUEL TANK DIFFICULT TO FILL AT TIMES"
Haven't you taken it back to the dealer yet? After all, you are under warranty. While the TSB is not 2007 specific, it still may be the solution for your problem. TSB's are not like recalls, they are advisories for dealers and the dealer can use them to solve problems outside the model year specified.
I'll bring it in when I have my first complimentary oil change done. I'll keep everyone posted...
It happened to me all the times even I have the shuttle value (1 time visit) and the whole gas tank replacement(2 time visit). now my 04 is out of bumper to bumper warranty. I don't know I should bring back to dealer or not.
Originally Posted by Spike100
Jim,
--Spike
--Spike
Nissan replaced my gas tank 3 times because of this and filled the tank up each time. Next time you fill up don't put the pump on the fastest flowing lock. Go down a notch or 2.
Bring it to the dealer, had this problem it was an airbypass valve or something. Had to bring it in so many times they ended up changing my entire tank. As they replaced the bypass valve they broke something in the tank. Good luck
