Just hit 60,000 tonight. Recap of problems to date
Old Jul 22, 2007 | 08:58 PM
iceagetlc's Avatar
iceagetlc
Default Just hit 60,000 tonight. Recap of problems to date
Thought I'd share the list of problems I've had had with my 03 up to now.
- Replaced transmission at 39,000. Grind into third
- Rear axle click at 45,000
- Window motor needed reset at 42,000
- Window grease on occasion. Seems to be random
- Only changed tires once. Rears at 51,000 and fronts at 58,000.
- Interior pieces such as radio controls and turn signal/wiper stems started to fade and discolor at around 55,000
- Only changed clutch once, was done with transmission at 39,000 but didn't even need it then.
-Oil changed every 3,000 or less with no signs of loss.
-Gas gauge is totally inaccurate, I've never put more than $50 in even when it's flashing "---" at me on the dte.
- Hatch hinges fail under cold temperatures
- Electric gas door has lost it's oomph to open at about 55,000. I now have to get a fingernail under it to open it.
- A/C is starting lose it's cool at about 55,000
Other than that, it's running pretty damn strong, and is ready to go F/I.
Old Jul 22, 2007 | 09:00 PM
JDMFairladyZ33's Avatar
JDMFairladyZ33
LOL...you forgot the fuel hose recall and tire feathering Sounds like she's ready.
Old Jul 22, 2007 | 09:08 PM
iceagetlc's Avatar
iceagetlc
Yea suprisingly no tire feathering experienced.
Old Jul 22, 2007 | 09:32 PM
stylett9's Avatar
stylett9
have you had problems with your rear hatch window vibrating? My 07 only has 9k miles on it and the rear hatch window vibrates pretty bad. Only thing that bothers me so far. Also, when you saw window motor had to be reset, does this mean replaced?
Old Jul 22, 2007 | 09:36 PM
iceagetlc's Avatar
iceagetlc
No, not replaced. It just was acting screwy whenever it was auto-closed. It'd always come back down a tad like something was caught in it.
And no, no other hatch problems. I have the rear window-wiper and dead-weight removed and even then nothing upset enough to cause rattling or squeaking.
Old Jul 22, 2007 | 09:59 PM
orangeflash's Avatar
orangeflash
that rear axle click, how much did it cost to fix that. Im asking this becuase I have some sort of click when I turn the steering wheel all the way and back up at the same time. Im not sure what it is..
Old Jul 22, 2007 | 10:10 PM
iceagetlc's Avatar
iceagetlc
The backing up part makes sense but it's nothing to do with the steering wheel. The stealership charged me $115 for the fix, although that was a while ago and may have been combined with an oil change or some other service. I never went for just one thing.
Old Jul 22, 2007 | 10:20 PM
Spike100's Avatar
Spike100
What about the cloth wearing/discoloring on the seats (usually reported on the outside side/bolster on the driver's seat)? I believe this is a common complaint on 2003 models with cloth seats.
--Spike
Old Jul 22, 2007 | 10:23 PM
iceagetlc's Avatar
iceagetlc
--Spike
It's really not that bad. I mean the seats are kind of plain to begin with, but if anything it just seems the threads are wearing thinner from being stretched, the color and shape are still perfect.
Old Jul 23, 2007 | 12:11 AM
andrew538's Avatar
andrew538
Dude, all I can say is ur ride is messed up man!! How did ur car get like that when u drive 30mph all the time? or ur car most be flying or something.
I remember I change my first set of tires before 15k, then I had change so many of them(mostly rear) that I lost count... over 80k miles. Windows were fu.ked up though, I do have electronic problem sometimes...
by the way, is royal purple better than mobil1 synth?
Old Jul 23, 2007 | 12:46 AM
black06z's Avatar
black06z
I know whatcha mean about that gas door cap. I have to press the button a few times before it releases enough to open.
Old Jul 23, 2007 | 04:07 AM
Kolia's Avatar
Kolia
What do you mean by the hatch hinges failing? The only way I can see a hinge fail is if the hatch/door falls off...
Old Jul 23, 2007 | 04:12 AM
MUZZY's Avatar
MUZZY
I have an 04.5Z 58k miles 0 problems
Old Jul 23, 2007 | 04:43 AM
FrankieZZ's Avatar
FrankieZZ
Default Fix for gas filler door
Two things : 1 . Hit the little black plastic lever that releases the gas filler door with some WD-40 oil every now and then ,working the lever in and out with the the oil on it , 2. before you get out of the car , hit the release button 3-4 times in a row . After a while , you don't even have to oil it hardly at all . It will open every time....
Old Jul 23, 2007 | 09:22 AM
Twon's Avatar
Twon
When you press the button to open the hatch, it pops, but not the whole way. you have to hit the button a second time while pulling the hatch up with your hand. its annoying.
ive probably experienced half to three quarters of the problems on that list. those are the more common ones.
Old Jul 23, 2007 | 09:36 AM
Kolia's Avatar
Kolia
That is a latch issue, not a hinge!
It should be adjustable fairly easily.
Old Jul 23, 2007 | 10:24 AM
iceagetlc's Avatar
iceagetlc
No, I was talking about the hinge. It will not support the weight of the hatch under 45 degree temperature.
Also, yea the latch sucks.
Old Jul 23, 2007 | 10:34 AM
SirSpeedyZ's Avatar
SirSpeedyZ
I have this problem too, it there a way to fix it?
Old Jul 23, 2007 | 10:36 AM
Kolia's Avatar
Kolia
Then it's the struts you're refering to!
The hinges are the things around which the tail gate rotate, near the roof...
Old Jul 23, 2007 | 10:53 AM
spacemn_spiff's Avatar
spacemn_spiff
Good catch.
