Wont go into first while driving?
Old Sep 14, 2003 | 07:27 AM
ares's Avatar
ares
Veteran
double clutching will do it.
as I said in another thread, 3 peices, the gears in the middle are not spinning fast enough to match the 1st gear up to the drive shaft. so if you go to nuetral, let the clutch out, rev it, put clutch in, hopefully the gears will then be going fast enough to match up without too much work from the synchros.
this should only be done in dire situations where you MUST have power now. otherwise second should be fine.
Old Sep 14, 2003 | 07:39 AM
haanz's Avatar
haanz
I am very new to all this double clutching etc. You are basically saying that you have to let the clutch out before you rev, and then put it back in and go. Is it bad to keep the clutch in, put in neutral, rev, downshift and go? I swore I saw it like that on a videotape of a pro. Then again I could be wrong.
Old Sep 15, 2003 | 07:30 AM
jckolnturn's Avatar
jckolnturn
Get the "Bullitt" DVD Steve McQueen double clutches his Mustang through the whole chase scene, I'm not sure why because those cars had synchros too but he does it.
Old Sep 15, 2003 | 05:33 PM
scottycoyote's Avatar
scottycoyote
hey every time i pull up on my emergency brake while im riding along......my car screeches to a halt and spins out......what am i doing wrong
Old Sep 15, 2003 | 05:38 PM
ares's Avatar
ares
Veteran
turn the wheel to the direction of the upcoming turn, release brake when at the desired angle, rev to 6grand release clutch. perfect 90degree turn.
Old Sep 15, 2003 | 06:10 PM
Buub's Avatar
Buub
Double-clutching, however, will slow you down in a real race. It's much quicker to single-clutch. In fact, if you are a perfect rev matcher you don't have to use the clutch at all.
Back to the first-gear synchro thing. Even if you could double-clutch them up to speed, I still think it's going to be very hard on them. They are geared really low so they are going to spin at a very high RPM if you engage them at too high a speed. They aren't made to spin that fast. No matter how you do it, it won't be good for them.
Old Sep 16, 2003 | 05:31 AM
supirio's Avatar
supirio
Originally posted by nissan350z
dont go into first until you've come to a complete stop. if you're not gonna completely stop...then second is the gear you wanna be in.
this is what i keep repeating to my friend who is learning to drive a stick on my Z
SAME HERE, my friend knows how to drive stick but insists on plopping into first while rolling, im like man stop doin that!!
MAsSIVrOOM
Oct 20, 2023 10:50 AM
Obadabot
Jun 18, 2023 11:31 PM
350Z_Al
Oct 29, 2020 07:44 PM
