just some questions...
Old Oct 6, 2009 | 08:14 PM
brandonsteez's Avatar
brandonsteez
Default just some questions...
So i went from an 04 big turbo srt4 to now an 03 nissan 350z track edition. i just had a couple questions, i read that that clutch is very noisey but mine sounds like its grinding. Everytime i take it out of gear it makes a grinding noise is this normal? Also it has a new brembo brake kit on it but there very squeeky i tried just using some brake cleaner anyway to get rid of this? also what do you want your oil pressure and volts gauge to be at cruising? if i think of anything else ill let you guys now thanks for any help its a bit different from the cert
Old Oct 6, 2009 | 08:43 PM
s31t8n8's Avatar
s31t8n8
did you push the clutch pedal all the way down?
Old Oct 6, 2009 | 08:53 PM
brandonsteez
yes i do
Old Oct 6, 2009 | 09:05 PM
s31t8n8's Avatar
s31t8n8
ok just making sure
Old Oct 6, 2009 | 09:54 PM
konaforever's Avatar
konaforever
The clutch is noisy, but it's a mechanical noise, not a grinding sound. So that doesn't sound normal.
Old Oct 6, 2009 | 09:58 PM
TittieZ's Avatar
TittieZ
With the brakes, if they are new and the pads are ceramic than they'll have a break in period. I personally would rather change out my brakes more often with the standard grade pads than deal with ceramic, I haven't been too impressed with the higher grade ceramic pads.
Old Oct 6, 2009 | 11:03 PM
winchman's Avatar
winchman
When I was looking at cars, I drove two used 2008 350Zs with manual transmission. One had a very noticeable grinding sound coming from under the car when it was idling in neutral with the clutch pedal up. The owner said it had always been like that.
The car drove fine, but the noise scared me away from considering buying the car. I can't imagine how the sound could have been normal. I didn't want to buy trouble, even if the car was still under warranty.
Old Oct 7, 2009 | 06:19 AM
diablox1's Avatar
diablox1
clutch "chatter" is very normal on 350Zs.
Old Oct 7, 2009 | 07:10 AM
XXL's Avatar
XXL
^+1 OP, this is well documented. do some searches, you will find lots of talk about this
Old Oct 7, 2009 | 07:20 AM
konaforever
Grinding isn't chatter.
Old Oct 7, 2009 | 09:38 AM
Wu-Watt's Avatar
Wu-Watt
Old Oct 7, 2009 | 10:11 AM
terrasmak's Avatar
Its probably the normal chatter.
Old Oct 7, 2009 | 10:43 AM
Chaser720's Avatar
Chaser720
Lemoned Z
And what the OP is probably hearing is chatter and is mistaking it for grinding.
Possible Light weight flywheel? If its been modded then its possible and that greatly increases chatter.
Old Oct 7, 2009 | 01:33 PM
winchman's Avatar
winchman
The last time I had to deal with clutch chatter was on a '54 Ford with worn-out engine mounts.
As for the oil pressure the OP was asking about, I got this info from the dealer (who said he got it from the service manual).
Minimum oil pressure (warm engine): idle....14psi, 2000rpm....43psi, 6000rpm...57psi
Miy '08 has less than a thousand miles, and the pressure is 30psi at idle and just over 60psi at 2000rpm.
ginobetterfly
Jul 31, 2007 04:31 PM
ginobetterfly
Jul 31, 2007 02:27 AM
MustGoFastR
Nov 29, 2006 05:21 PM
ANXIOUZ
Southern California
May 16, 2006 02:17 PM
jkoc
Jun 4, 2005 07:24 AM
