limited slip differential... Which 350z's have it?
Old May 15, 2010 | 05:54 PM
  #41
pangoman's Avatar
pangoman
Originally Posted by FineWine
That particular engine was just an example. Built b18s have existed well before that motor was born. I'm sure you knew that, though.
The B18's in that time frame were rated at 130 - 140 HP stock (NOT wheel HP at that). Again, I stated that while it was possible for 12.8 out of a CRX, I thought I was pretty clear in stating that I believe it highly improbable that BJJ did it. In other words...I was calling BS on him.
Old May 15, 2010 | 06:46 PM
  #42
Ruthless18x's Avatar
Ruthless18x
Ah BJJ, the originator of being rimmed up with a killer system.
Old Dec 17, 2012 | 10:57 PM
  #43
soulfulstrum131's Avatar
soulfulstrum131
well honestly, I would switch the LSD, stock LSD's are no bueno
Old Dec 18, 2012 | 02:40 PM
  #44
mr. sparco's Avatar
mr. sparco
^ Did you notice the date of the last response?
Old Jun 19, 2015 | 04:22 AM
  #45
walayang's Avatar
walayang
Default help!!how to install cusco lsd
hi all
i've order a cusco lsd from cusco japan.the part number is lsd 251 L15.but after i remove the oem lsd.i have no idea to install the cusco lsd.
and i take a pic.do i got the wrong item?or something mistake.help.please.help!!
the left is vlsd the right is cusco lsd.
Old Feb 25, 2017 | 07:41 AM
  #46
Zclumpy's Avatar
Zclumpy
My 03 enthusiast has an open diff
Old Feb 25, 2017 | 09:36 AM
  #47
dcains's Avatar
dcains
All except the base came with the VLSD. Perhaps your VLSD is just worn out? It happens, and other than to open up the pumpkin and replace the entire diff assembly (such as with a Quaife, WaveTrac, OS Giken, etc.) it's not serviceable.
Old Oct 5, 2020 | 01:05 AM
  #48
Zoe Kent's Avatar
Zoe Kent
Hi, I am sure Nissan base variant don't have LSD in it. I can give you more Nissan models having LSD in it. Check our Nissan Cars in UAE.
Old Oct 8, 2020 | 10:03 AM
  #49
OohShiny's Avatar
OohShiny
Not all Tourings have VLSD - my 03 Touring definitely did NOT have it. ( I just swapped the diff, so 100% sure about this. ).
aarrgghh
May 1, 2022 11:04 AM
Workshop12
Mar 23, 2020 01:45 PM
hulkout
Aug 15, 2019 02:01 AM
Justin100
Nov 29, 2015 03:58 PM
hardkicks
Sep 20, 2015 12:28 PM
