Miss Shift
Old Jul 27, 2010 | 09:52 AM
  #41
Hsummer's Avatar
Hsummer
Originally Posted by 350ztttt
You just really huurt your pistons, and more specifically o-rings.
Everytime you downshift, it strains the o-rings, which is why driving a car 'nicely' and not downshifting 3 gears on a whim will generally increase the longevity of the car. What you did was probably equivalent to 40-60 regular downshifts.
I did this in my friends s2k because i wasn't used to a decent non clunky-*** shifter, and threw it from 6th to 2nd going 55mph. It still runs fine a year later.
btw i'm no s2k fanboy, that was the lamest car in the world to drive.
Of course it would run fine a year later, that car doesn't redline until 60 in second. 55 mph is well within the second gear rev range.
My pistons always tell me they hurt after I downshift 3 gears. But my o-rings only strain when I downshift 4.
Old Jul 27, 2010 | 07:29 PM
  #42
Elperuano's Avatar
Elperuano
Originally Posted by Dr. Venture
damn. and i thought armoralling my shifter was bad when i slipped right off and punched the dash. You should be fine.
Least you found the gear. Could of been worse. " if you can't find em grind em"
lol @ punching the dash! Thas a major slippage with a mean shift! U must've been mad at sumthin to be shifting that hard!
Old Jul 27, 2010 | 07:44 PM
  #43
TheFarmer's Avatar
TheFarmer
Really? Because what you did is equivalent to 40-60 regular downshifts.
Old Jul 27, 2010 | 08:03 PM
  #44
Spork's Avatar
Spork
You would have noticed something immediately if serious damage occurred.
I know from experience. You ever hear a built Toyota 2ZZ engine with wide open exhaust ports and race exhaust at 12k rpms?
Old Jul 27, 2010 | 08:09 PM
  #45
TheFarmer's Avatar
TheFarmer
Uhh... If they're wide open ports, what's the point of a race exhaust.
Old Jul 28, 2010 | 11:13 AM
  #46
Hsummer's Avatar
Hsummer
If you know how to rev-match you can skip however many gears you want, the synchro's don't have to do any work. Are you trying to tell me that shifting from 6th to 2nd at 40 mph, with correct rev-matching, in my current car is like 40-60 regular downshifts? That makes no sense.
Old Jul 28, 2010 | 11:19 AM
  #47
Nexx's Avatar
Nexx
you just really huurt your pistons, and more specifically o-rings.
Btw i'm no s2k fanboy, that was the lamest car in the world to drive.
cocaine, its a helluva drug!!!
Old Jul 28, 2010 | 11:45 AM
  #48
TheFarmer's Avatar
TheFarmer
Hsummer, I was being sarcastic and poking fun at the guy you quoted
Old Jul 28, 2010 | 11:53 AM
  #49
Hsummer's Avatar
Hsummer
<- Long day at work.
I was starting to get worried about this forum.
Old Jul 28, 2010 | 12:11 PM
  #50
JCat's Avatar
JCat
Please explain this. I think there might be a few people laughing at you.
Old Jul 29, 2010 | 04:02 AM
  #51
Hsummer's Avatar
Hsummer
I'm guessing by his name that he has 4 turbo's on his car, so I can see how his pistons would be hurting. Still waiting on an answer on the o-rings though.
Old Jul 29, 2010 | 01:55 PM
  #52
LuciaPwNs's Avatar
LuciaPwNs
oh the 2ZZ <3 i loved that high revving engine! i still have her but she is my bros now
Old Jul 29, 2010 | 07:34 PM
  #53
BonesZ33's Avatar
BonesZ33
watch out for rod knock, or a spun bearing.. cut open your oil filter and check for metal.. don't let it happen again.
Old Jul 31, 2010 | 08:53 PM
  #54
norapat01's Avatar
norapat01
I wouldn't worry about it too much.
Old Jul 31, 2010 | 08:59 PM
  #55
Spork's Avatar
Spork
Meaning bent valves.
Wat?
Old Aug 9, 2010 | 03:27 AM
  #56
TheWan's Avatar
TheWan
First of all, if it's 05 or older, you'll be fine. remember, they used almost exactly the same engine part for 05 anniversary with 7000 red line... unless you did over 7000 (which is NEARLY impossible going 4 to 2nd.), you'll be fine. if it's 06 or newer with high rev engine, i wouldn't know what to tell ya.
Old Apr 3, 2013 | 01:18 PM
  #57
MyO3Z's Avatar
MyO3Z
Bringing this back from the dead. I have done the same thing....it is not impossible to go over 7k. My car hit 8k. I was doing a pull (roughly a 1/4 mi) and was shifting perfectly, but went from redline in 3rd, to 2nd. I pushed the clutch in right away after letting it out, but it was scary. Everything runs fine and sounds great still, i think the bulk of the damage was to my clutch, which I'm fairly certain is OEM and I'm at 95k miles, so I'm not too worried.
I'm not new to manuals, but this is the shortest throw shifter I've driven.
Old Apr 4, 2013 | 01:21 AM
  #58
StuLax18's Avatar
StuLax18
General & Tech Moderator
I miss Shift also. Where did he go?
Old Apr 4, 2013 | 08:35 AM
  #59
Phenom's Avatar
Phenom
Toasty
I think its Mrs. Shift now.
MAsSIVrOOM
Oct 20, 2023 10:50 AM
sherm
Apr 11, 2020 05:21 PM
Jambo016
Sep 16, 2016 01:08 PM
