Hey guys, please some advice!
Old May 15, 2013 | 10:08 AM
CALI360Z's Avatar
CALI360Z
Originally Posted by DayZblue350Z
thanks, i noticed yesterday when i went into a hard right in 3rd and slid out that i did a little bit of drifting lol just wasnt sure if i looked like a badass or like a 1wheeler
Im having some trouble guys! I have a 07 350z hr, i installed some short ram intakes without the heat shields, and was getting to much hot air in and the car was going from 1 rpm to 500(below 1) and acted like it was gonna turn off wich it did when y came to a stop or light. When driving without stoping was good.i know installed the heat shields and the car now dosent turn off and does it a little less, check engine comes on. When a/c is on it does it a little more , what do you think!
Old May 15, 2013 | 10:35 AM
Phenom's Avatar
Phenom
Toasty
1 rpm? That's awfully slow.
Sounds like your maf is all fcked up
Old May 15, 2013 | 10:51 AM
Flick Montana's Avatar
Flick Montana
If this was on the street and not the track, please try not to take anyone else with you when you slide through the pearly gates on your roof.
Old May 15, 2013 | 11:12 AM
CALI360Z's Avatar
CALI360Z
It stays at 1thousand rmp at the number one in the rpm gauge then it goes down to half (between 1 and 0) and then up again to 1 like in 3-4 seconds and it does that more when the a/c is on, it did it worse when it didn't have the intake heat shields on. Im really stressed, what do you think is going on!? Appreciate the info.
Old May 15, 2013 | 11:26 AM
Syner's Avatar
Syner
Read Phenom's post, sounds like your MAF. Also, you don't have to quote everything.
Old May 15, 2013 | 11:34 AM
CALI360Z's Avatar
CALI360Z
Ok thanks, how can i know wich maf? Or do i have yo change both!? Is it better to buy new or used! Thanks sorry for that. How can i post pics? Jaja im kind of new.
Old May 15, 2013 | 12:55 PM
stuartc323's Avatar
stuartc323
if you have an HR motor you have to check both MAF sensors to make sure they are good. You have two throttle bodies meaning you have two intake points, if im not mistaken the maf sensors should be where the intakes are.
Old May 15, 2013 | 12:59 PM
CALI360Z's Avatar
CALI360Z
Yes i know where they are, but how do i know if they are bad? And is it better to get new than used?
Old May 15, 2013 | 01:04 PM
stuartc323's Avatar
stuartc323
there is no way real way to check other than by 1. running a diagnostic on your car, 2. using a voltmeter to check the send and return voltages on your Maf, or 3. You can clean the MAF and run it around the block if you dont want to do either of those and see if your car returns to normal, but other than that those are your options
it is also better to buy new, you cant get MAFs for cheap from courtesyparts.com or z1motorsports.com
Old May 15, 2013 | 01:17 PM
CALI360Z's Avatar
CALI360Z
Thanks really appreciate it. Will look into that.
Old May 15, 2013 | 02:06 PM
Flick Montana
I can tell you're stressed. You quoted the wrong person in your reply.
Old May 15, 2013 | 02:31 PM
stuartc323's Avatar
stuartc323
Lol you didnt have to get him Flick, he is already worried about the car enough ahah
Old May 15, 2013 | 04:51 PM
Flick Montana
Not trying to be mean, just thought it was funny.
Old May 15, 2013 | 06:52 PM
DayZblue350Z's Avatar
DayZblue350Z
well considering it was an accident and i wasnt trying to do SIKK DRIFFTS like thanksgiving pole guy...
no ****. i went into a turn and slid out instead of slamming the brakes and spinning out i powered through it.
Old May 16, 2013 | 03:07 AM
Flick Montana
Always power out, bro.
Old May 16, 2013 | 02:51 PM
N80's Avatar
N80
Accident? Get thee to an HPDE!
Obadabot
Jun 18, 2023 11:31 PM
liqalu04
Jan 2, 2022 12:58 PM
