Slip light
Old Jun 16, 2014 | 08:05 AM
idriveslideways's Avatar
idriveslideways
Default Slip light
I put Rota P45R's on my 2007 350z and randomly the slip light flashes and I don't get any power. This also happened when I had a tune up done on my car and they rotated my front wheels to the back. I know my tires aren't losing grip. Does this happen to anyone else? How do I fix it?
Old Jun 16, 2014 | 08:36 AM
frocker93's Avatar
frocker93
how much stupidity do we have to deal with?
You realize that we have staggered wheels for a reason right? (probably not). You can't rotate your tires and the shop who did that you should not go back to.
On a serious note, what tires and wheel sizes/widths do you have?
oldschool350z's Avatar
oldschool350z
Why would you rotate your front wheels to the back?
The z is supposed to have staggering tires meaning the larger are in back. What size tires are on your rear and front wheels?
Old Jun 16, 2014 | 08:45 AM
Syner's Avatar
Syner
Seriously, OP? Troll?
Old Jun 16, 2014 | 08:48 AM
travlee's Avatar
travlee
Master
wow, just wow
Old Jun 16, 2014 | 08:50 AM
Syner's Avatar
Syner
but he's a drifter, yo!
Old Jun 16, 2014 | 08:51 AM
travlee's Avatar
travlee
Master
i mean i have square 9.5 on my wheels, but my tires are diff sizes..... i dont have any issues..
Old Jun 16, 2014 | 10:08 AM
StuLax18's Avatar
StuLax18
General & Tech Moderator
I run 295s in the front, 265s in the back. Honda drag racer style.
Old Jun 16, 2014 | 10:10 AM
Syner's Avatar
Syner
Old Jun 16, 2014 | 12:45 PM
idriveslideways
Yes, I know they are staggered. When I got home, I rotated the wheels back to where they were supposed to be.
Current tire size is 225/50/17 front and 245/45/17 rear.
Old Jun 16, 2014 | 12:56 PM
Jah70's Avatar
Jah70
wtf? Did you ever read your owner's manual? Your not suppose to rotate the tires. A tune up shouldn't interfere with the slip light coming on. Also, these cars get really agitated when you use wheels that aren't within the stock perimeters.
Old Jun 16, 2014 | 01:33 PM
idriveslideways
I know that. I didn't rotate them.
Does anyone actually know why it does this?
Old Jun 16, 2014 | 01:34 PM
92K1500's Avatar
92K1500
225/50/17 Overall Diameter: 25.86 in
245/45/17 Overall Diameter: 25.68 in
Your back tires are spinning faster than your front tires due to the smaller size.
It wont take much at all for the traction control to engage.
Old Jun 16, 2014 | 01:35 PM
Jah70's Avatar
Jah70
Put the stock wheels back on (correctly) if you still have them to see if anything changes.
Old Jun 16, 2014 | 01:50 PM
idriveslideways
Finally a good answer! Ok, I'll change the rear tire size. Thanks!
Old Jun 16, 2014 | 02:57 PM
92K1500's Avatar
92K1500
You just bought the rears correct?
The fronts are too big. Stock is 225/45 not 225/50
Old Jun 16, 2014 | 04:38 PM
idriveslideways
Negative, I bought all four. I have 225/50/17 in the front and 245/45/17 in the rear. I thought that the diameter was the same, but I was off by a bit. I am off by about 2/10ths of an inch.
Now that I know that, it's not a big deal. I'll just drive with the traction control off until I get the correct sizes tires.
Which may be a while, cause the Army doesn't pay for ****.
Old Jun 16, 2014 | 04:44 PM
oldschool350z
It doesn't take much to throw off the z and traction control...
I would drive with vdc off and hopefully then there will be no issue. But iwouldd change the front tire size back to 45 asap
Old Jun 16, 2014 | 05:41 PM
frocker93's Avatar
frocker93
It's like a 3% difference isn't it? OP, I believe stock 17's are 225/50 and 235/50. Just grab a pair of 235/50 for the back and everything should be peachy.
loudtoyz
Apr 6, 2023 04:52 AM
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
