New wheel question?
Old Mar 27, 2018 | 01:06 PM
Pattyplaid's Avatar
Pattyplaid
Default New wheel question?
I’m looking at getting some new wheels and had a question about weather or not they would fit correctly. I am wanting to run 19x10.5 in the rear and 19x9 in the front with a 20 offset on all 4. This is my first time buying custom wheels so don’t know much about them.
Old Mar 27, 2018 | 01:53 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
They'll fit fine. Just watch the rear fender lips for clearance but +20s should work OK without rolling depending on whether you are lowered or not. Personally I'd go 9.5 in front.
Tire sizes that work with no issues: 245/35 & 275/35 F-R OR 255/35 & 285/35 (a little snug if lowered and not rolled but only requires slight roll to fit)
Old Mar 27, 2018 | 04:31 PM
Pattyplaid's Avatar
Pattyplaid
Thanks for the help! Would it be better to go with the same size all around or does a staggered set work better?
Old Mar 27, 2018 | 04:34 PM
Pattyplaid's Avatar
Pattyplaid
They only come in 19x 10.5 or 19x9 so woukd it better to do one size all around
Old Mar 27, 2018 | 05:05 PM
MicVelo's Avatar
Ouch. You probably don't want to get me started on the "square vs stagger battle", hahahahaha....
But here ya go, stagger is factory engineered into the Z33 due to its suspension type and said design's(not the car necessarily, just the type of suspension) propensity towards snap oversteer.
No, it's NOT generally a problem. The Z is an UNDERsteering pig out of the box as a matter of fact. But.... I (as in IMO) prefer the way the car turns in with sharp steering response and the rear end is controllable with throttle using stagger setup.
That's ME. Others will tell you otherwise and suggest that a square setup mitigates understeer and to some degree it does because if you think about it logically, adding more tire to the front adds a bit more grip so the front is then less prone to washing out. All good, but I just don't care for the feel.
So, what's the answer? I'd say to generalize it, if you are tracking and you know what type of handling characteristics you want/need for your local track then adjust as needed (meaning, go square if that suits your track).
But for every day driving, there's no real need to do so. Stick with stagger.
OK people, have at it....
EDIT: so far as the 9/10.5 versus 9.5/10.5, ehhhh, don't worry about it. That .5 isn't going to make THAT much of a diff and should be fine if 9.5s aren't available.
Oh, and I don't usually toot my own horn but if you need to get a slightly better understanding of offset and what it does for (and against) you, here: https://my350z.com/forum/wheels-and-...t-novices.html
Old Mar 27, 2018 | 05:28 PM
Pattyplaid's Avatar
Pattyplaid
thanks for your help man I think I’ll give with the staggered! So 275/35 on the back and 245/35 on the fronts will work well?
Old Mar 27, 2018 | 05:50 PM
MicVelo's Avatar
Tried and true setup.
Since I'm a "visual person", here's those exact sizes on my car with 9.5 +19/10.5 +29:
Same size wheels, F&R +22mm with 255/35 and 285/35 (but note that my fenders ARE rolled for clearance for my +15s so just about anything fits now):
Good luck! Post pics when done!
Old Mar 27, 2018 | 09:02 PM
CK_32's Avatar
CK_32
Just a FYI I have a few friends who run 9.5/10.5 and they regret not going 10.5/15mm offset square on the track.
And each of them HEAVILY told me to go square. That said, I have 10.5 square I just got in last week. I’ve only mounted them and being OCD, I wish I went with 10 square for looks. But my car is a track project so the extra .5” of rubber is better than the little bit of wheel sticking out past the fenders.
But if you’re just going for looks, the 10” will be EXACTLY flush with your fenders and not stick out any. Again off friends advice go square if you plan for track use.
Old Mar 28, 2018 | 04:55 AM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
Probably ordering 19s that weigh 30lbs each... My guess would be not concerned about the track use or the discussion would be 17s or 18s
Old Mar 28, 2018 | 07:49 AM
MicVelo's Avatar
Oh you mean like Nismo V3/GT wheels? Front 18x9 are OK at 20# but the rear 19x10.... 29.4lbs.
My 19x9/19x10 LMZ5 S-Tunes.... 20lbs each. Bishin' dude!
My Volks in 9.5/10.5 are relative boat anchors at 24 and 26 F-R. (But somehow they work very well on factory Niz)
Old Apr 3, 2018 | 11:52 PM
Fernin_Z33's Avatar
Fernin_Z33
If you are more into the stance side of 350z's just go with 19x11 all while being on 275/30/19.
Old Apr 4, 2018 | 07:24 AM
MicVelo's Avatar
Welcome.
Nice ride!
mpe488
Jul 20, 2010 12:56 PM
Jon70ProofZ
Jan 27, 2010 09:13 PM
MyZ4U2C
Jun 10, 2009 07:42 PM
SilverZGirl04
Apr 18, 2006 10:16 AM
nismor33
Australia/New Zealand
Jul 10, 2003 10:09 PM
