350z will not start at all
Old Oct 28, 2019 | 09:17 AM
Mitchell Bauer's Avatar
Mitchell Bauer
Default 350z will not start at all
I have a 2004 350z Coupe, and this morning when I tried to start it up for school, it would just keep cranking, but would not start. Eventually, after about 5 minutes of trying, it started, but it sounded like a literal lawn mower. It sounded like the thing was running on 1 cylinder. white smoke cane out, but they could be because of the cold weather here in Texas. But not even 5 seconds later the car stalled. Mind you I drove the car once in the period of 3 days, so that maybe because why. But I connected my OBD scanner and these were the results. The current mileage on the car is 152,583.
Old Oct 28, 2019 | 09:37 AM
jhc's Avatar
jhc
General & Tech Moderator
Where did the smoke come from- engine or exhaust? If exhaust that's not good, possible head gasket problem. Check for coolant on oil dipstick and oil in radiator.
What has changed since the car ran well? Has it over-heated? Have you done any recent work?
Old Oct 28, 2019 | 09:40 AM
Mitchell Bauer
Unfortunately the smoke is coming from the exhaust. Nothing has changed with the car. The 1 time I drove it was around the block so it was running for only 5 minutes. I have not done any recent work, besides new tires which was around 3 weeks ago. The car had overheated before due to a cracked radiator, but I got it replaced around 4 years ago. But the car ran at optimal temperature a couple of days ago.
Old Oct 28, 2019 | 04:04 PM
jhc's Avatar
jhc
You're honestly gonna have to do a little research on this. Simply posting "my car runs like crap" on the forum isn't going to generate a lot of accurate answers.
You ALWAYS have to ask yourself- What has changed since it ran well? The answer could be as simple as bad/low octane fuel. If you don't drive it much I'd suggest any Lucas fuel stabilizer to reduce any moisture you have in the tank. GL.
Old Oct 28, 2019 | 04:50 PM
travlee's Avatar
travlee
Master
Jeebus
travlee's Avatar
travlee
Master
Btw, it's not even cold in texas
Old Oct 29, 2019 | 12:21 PM
Spike100's Avatar
Spike100
Hi Mitch. As others suggest, it could be the head gasket, but this usually exhibits symptoms over a longer period of time. You are experiencing failure suddenly. I'm guessing, but I think your problem points to a failing coil-pack. At least check that.
Old Oct 30, 2019 | 08:46 AM
Mitchell Bauer
Found the problem! Faulty starter. Currently at the repair shop. Managed to get it started so I could drive it over there and be said faulty starter.
Old Oct 31, 2019 | 06:32 PM
CFAUVEL's Avatar
CFAUVEL
having a faulty starter is not going to make your car poorly once it DOES get started.
On your first post you stated a bunch of problems.
  • 'kept cranking and cranking'...that is not a bad starter.
  • "It sounded like the thing was running on 1 cylinder. " - not the starter UNLESS it remains engaged, but doubt it.
iheartmyz
Apr 10, 2020 08:28 AM
chrisz33
Oct 4, 2017 07:48 AM
Wsheff
Apr 15, 2017 04:50 PM
DML85
Oct 11, 2009 05:00 PM
350zphien
Jan 11, 2008 01:11 PM
