Car won’t start .
So I’m new to this and I made an account to see what I need to do . I have a 2003 350z 6 speed and I have just replaced the clutch and fly wheel with a stage 2 platinum racing clutch and fly wheel . Done the job in a little over 6 hours got my car back together and the thing will not start . I’ve been told it was because of the crank sensor right by the fly wheel . I’ve also noticed that my Rpms are not moving at all when I turn it over . Is there a way to get a crank sensor to match it or am I dead in the water with that fly wheel ?
Or, it could be something else fairly minor (like the starter not being re-installed correctly if you removed it or not connected properly).
Sadly, it sounds like you need to remove everything you just did and align the flywheel correctly. There's a small dowel pin to use for the correct alignment.
Another suggestion, Pull your Crankshaft Position Sensor and ensure you did not inadvertently damage it during re-assembly. If you do tear everything back apart, inspect the flywheel and ensure it is not damaged. Damaged teeth on the flywheel do occur and are easy to overlook.
nkohler
May 20, 2024 03:16 PM
turboex
May 26, 2005 11:12 AM
