100k maintenance on my HR. Let me know what I else I need.
Old Nov 18, 2019 | 08:09 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
Default 100k maintenance on my HR. Let me know what I else I need.
What else do I need? I already did the oil, trans fluid, and going to change out the bulbs in the headlights. It was a Florida car so most things are in pretty good shape.
Other than the spark plugs is there anything else the engine needs?
Ill change out the struts over the winter as those are probably not up to snuff anymore. Are there any bushings that wear out in 100k on these vehicles? (other than diff bushings but I'll do that over the winter too)
Please let me know anything else I should be adding to this cart before I order. Thanks guys.
Old Nov 18, 2019 | 08:19 AM
travlee's Avatar
travlee
Master
Rear diff oil.
Old Nov 18, 2019 | 08:32 AM
Bmsluite's Avatar
Bmsluite
5 Year Member
I'm going to let the read diff be for now. No point in changing the oil if I'm just going to be installing a clutch LSD in the near future.
Old Nov 18, 2019 | 10:24 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Don't forget the engine drive belt.
Old Nov 18, 2019 | 11:48 AM
terrasmak's Avatar
The intake boots on mine were dried out and tearing, I swapped to the Z1 silicone intake pipes
Old Nov 18, 2019 | 04:59 PM
Bmsluite's Avatar
Bmsluite
5 Year Member
Good call on the drive belt. Checked my intake boots. They felt new. Actually, my entire engine looks brand new. I have never had a vehicle with such a clean engine bay
Old Nov 18, 2019 | 08:46 PM
813_350Z's Avatar
813_350Z
I'd really reconsider buyingan aluminum radiator from Koyo or other known brand (the larger capacity aluminum radiator). If you ever plan to do anything with the car there is no point in replacing it then. Throw a little extra cash on one of those radiators since you are already replacing it and be done.
Old Nov 19, 2019 | 12:09 PM
iideadeyeii's Avatar
iideadeyeii
Are you just replacing the radiator to replace the radiator? Never heard of someone doing that for "maintenance"
Old Nov 19, 2019 | 12:17 PM
813_350Z's Avatar
813_350Z
He mentioned in his purchase thread that it the OEM unit has a leak.
It's common here in Florida with the heat from the engine plus the weather. The cheap OEM units tend to crack after a while.
350ZToeRing
Aug 7, 2013 10:29 AM
DJMatrix1067
Oct 28, 2008 12:30 PM
MIAPLAYA
Jun 20, 2008 06:26 AM
DeeZee
Jun 24, 2006 05:51 PM
yacoub
Jul 7, 2005 05:02 PM
