Dumb Donor Question Need Help Motor Blown
Old Dec 14, 2019 | 06:41 PM
ltonyldavisl's Avatar
ltonyldavisl
Default Dumb Donor Question Need Help Motor Blown
Dumb donor question but my engine is flooded out. Ended up getting Exact same VQHR From an wrecked AT shell.
Trying to find a thread that has the things I’ll need to Upgrade and finish moving the new donor to the new car
Old Dec 14, 2019 | 07:28 PM
813_350Z's Avatar
813_350Z
Same year, same engine, etc?
Old Dec 15, 2019 | 07:12 AM
ltonyldavisl
Yeah Except the donor motor came from a AT trans... What do I need for my 6MT?!??
Old Dec 17, 2019 | 12:06 PM
icer5160's Avatar
icer5160
I could be wrong, but I don't think you need anything. To be clear your original Z is a 07-08 6MT? You're not trying to convert an auto-trans over to a 6MT?
If that is the case, you should be able to re-use all the existing components from the original engine/trans. The main difference will be the flexplate for the auto-trans. Just swap your flywheel and clutch over from the old engine. I'm not sure on the mileage, but it would be recommended to replace or upgrade the clutch hydraulics, inspect items like motor mounts, steering rack, trans mount, and maybe replace gaskets while you're at it. There's a oil galley gasket that commonly fails on the HRs within the timing case (causes major oil pressure loss), I would replace that on the donor engine before it goes in the car. If you want to be thorough, do a deep cleaning in the engine bay while it's empty.
Good Luck!
-Icer
Old Dec 17, 2019 | 11:16 PM
813_350Z's Avatar
813_350Z
If that is the case, you should be able to re-use all the existing components from the original engine/trans. The main difference will be the flexplate for the auto-trans. Just swap your flywheel and clutch over from the old engine. I'm not sure on the mileage, but it would be recommended to replace or upgrade the clutch hydraulics, inspect items like motor mounts, steering rack, trans mount, and maybe replace gaskets while you're at it. There's a oil galley gasket commonly that fails on the HRs within the timing case (causes major oil pressure loss), I would replace that on the donor engine before it goes in the car. If you want to be thorough, do a deep cleaning in the engine bay while it's empty.
Good Luck!
-Icer
Now is also the best time to slap on a twin-turbo setup.
You won't need anything. The main thing to remember is to pull out the pilot bushing and replace it with a 6MT bushing and that you can't use the bolts from the 5AT to hold your flywheel on. You will need the bolts from your 6MT.
Old Mar 11, 2020 | 07:42 PM
ltonyldavisl
I’m guessing I need the ECU from the donor engine
Old Mar 11, 2020 | 07:55 PM
dkmura's Avatar
dkmura
General & DIY Moderator
Why are you guessing? Your original ECM should work with the replacement VQ35HR. Switching the donor ECM over to your manual Z will not help.
Old Mar 13, 2020 | 09:50 AM
jhc's Avatar
jhc
General & Tech Moderator
And while you're swapping convert the slave cylinder to external setup. Thank me later.
absurdparadox
Apr 17, 2017 08:00 AM
CanadianDream
Mar 5, 2012 10:54 PM
Wild350z
Oct 25, 2010 06:27 PM
Blackbird CPV35
Feb 14, 2008 08:49 AM
Xx SiFaKa
Jan 27, 2007 11:39 AM
