350Z Hidden Features
Interesting quirk and feature #6:
If you open the cover of the little cubby holes, press upwards on the inside and pull it out you can fit at least a compact or subcompact Glock handgun under the little metal bar it rests on. Reinsert the tray and no one will ever know!
I put mine there when I went on a cruise a few years ago and the car was parked for a week. I figured it was safer there than in the glove box where if someone had pried it open "the glovebox" they would have noticed the glovebox "mat" and found the tray beneath, where a Glock and extra ammo also fit nicely btw 😁
Should be in the trunk. Federal law mandates that there be a release lever in any "trunk" area with whatever amount of cubic storage space they say.
1) If you hold the unlock button on your key fob the windows will roll down.
2) If you insert your keys into the cylinder lock on your driver's door and hold it clockwise & the windows will roll up
(I believe that if you turn the key in the door lock and hold it counter clockwise, it rolls the windows down)
3) If you car does not beep when you look it (or) if you do not want it to beep simply hold the lock button and the unlock button at the same time.
(Ok THAT I didn't know...my wife's g35 doesn't beep and we didn't know why it all of the sudden stopped...this is probably why)
https://my350z.com/forum/body-interi...mpartment.html
BTW you can put another "glove box" behind the driver's seat.
I have a JL Audio Stealthbox that I'll be installing for the subs, so I have no need for the BOSE subwoofer location.
absurdparadox
Jan 27, 2022 06:51 AM
