My nismo is sputtering/hesitating under load
Old Dec 15, 2022 | 08:14 AM
Atjstballin's Avatar
Atjstballin
Default My nismo is sputtering/hesitating under load
Here's the details,
1. Happens when Car is cold
2. Only under Any sort of moderate acceleration
3. Happens in all gears
4. No issues when idle
4. after like 30 seconds of sputtering, the car is perfect,
5. No codes.
Mods, high flow cats, z1 single exit exhaus. Nismo intakes, everything else stock.
car has 53k miles, I'm looking to change spark plugs maybe they are having an issue when cold.🤷‍♂️
Any ideas? 😂
Old Dec 15, 2022 | 08:55 AM
travlee's Avatar
travlee
Master
i would check for vacuum leaks
Old Dec 15, 2022 | 10:36 AM
Atjstballin
Default .
I hear a light popping sounds near the top centerof the engine when cold. Do you think that could that be a vaccume leak?
Old Dec 15, 2022 | 04:02 PM
icer5160's Avatar
icer5160
You could have a vacuum leak, weak fuel pump, faulty injectors, or faulty coil packs. Another possible fault could be the cam or crank sensors, but unusual to see these go on a vehicle with only 53k mi. What year is the Z? Is this a DE or HR? I'm guessing HR since you said Nismo intakes (plural). I would try to smoke test your intakes, check for any signs of a leak. But before going any further and guessing, get a OBDII scanner on the car and check for any pending fault codes. With the type of issue you described, I would imagine the CEL to be on.
-Icer
Old Dec 15, 2022 | 06:53 PM
Atjstballin
-Icer
Yeah its an HR, I can hear a small very inconsistent tick sometimes with what also sounds like whistling (especially when cold), just cant pinpoint where its coming from yet. I would assume an exhaust leak could have for the car to run like this when cold, then expand as it gets warm, resulting in the issue going completely away?
Old Dec 16, 2022 | 07:31 AM
bre240z's Avatar
bre240z
check the coil packs. You can disconnect one by one and if the idle does not change that coil pack is no good. Had something similar to this happen to me and it was a coil pack. Service light was not even turning on. Finally i put a scanner on it and sure enough one of the coil packs
Old Dec 16, 2022 | 01:00 PM
lifekenophobic's Avatar
lifekenophobic
When you feel the sputtering/hesitation, try mashing the throttle to see if that makes it stop. If so, congratulations! You get to spend $1,000 on new VTC covers like I did a few years back. Apparently quite a few HR's have this issue.
I hope for your sake it's as simple as some of the other suggestions that everyone had, if not I recommend reading my post here: https://my350z.com/forum/maintenance...l#post10886135
Old Dec 16, 2022 | 08:22 PM
icer5160's Avatar
icer5160
I hope phobic wrong! I would think it really strange if your VCT covers crapped out at 53k mi. Typically these last a really long time unless running with extended oil changes (every 10k mi or something). Change your oil often on these cars! Manual states every 3750mi for my 06. I do it every 3500mi. Oil is cheap! Engine repairs are not!
Cheers!
-Icer
Old Dec 19, 2022 | 06:31 AM
lifekenophobic
Cheers!
-Icer
Mine took a dump around 95k miles, and I change my oil every 3k miles with Mobil1 synthetic. Replaced the covers 5 years ago and haven't had one performance issue since.
It's kinda like gallery gaskets for the HR. Some people might have them fail at 50k miles, some people might not have any issues at all. Just luck of the draw. I do know the magnets in these VTC covers are very sensitive, and I believe that's the part that fails.
Old Dec 19, 2022 | 07:48 PM
icer5160's Avatar
icer5160
Wow, guess it's just luck of the draw. I can't believe how expensive the VCT Covers are. Fingers crossed I never run into this issue on my revup DE.
-Icer
Gooey
Mar 8, 2006 07:30 AM
Georgidis
Feb 12, 2004 08:42 PM
fairladyZ in Japan
Sep 23, 2003 04:39 AM
BlackZ33
Jun 13, 2003 06:13 AM
