There are actually two sensors there. The black connector is for your outside ambient temperature sensor (used for climate control and shown on the center dash multi-display). All yellow wire harness plugs indicate SRS system, the one in the front under the latch is your front impact sensor. There's a steel Z bracket that mounts there with 2x10mm nuts (you can see the posts in your pic).
Hope that helps!
-Icer
I have only been a Z owner for a little over a year and im still getting to know these cars. Always good to read through these threads. Good info even if youre not the one asking for help.
