Should gauges be illuminated?? Daytime running lights?
Old May 17, 2008 | 12:17 PM
Nunzzio's Avatar
Nunzzio
Default Should gauges be illuminated?? Daytime running lights?
Another illumination question...I have my 04 touring roadster in the garage and when I start it up, my dash/guages light up as if I turned my headlights on. It is as if I have an automatic setting on my headlight switch, and upon startup, it senses the dark conditions in the garage and turns the lights on. I am unable to check if the dash lights are on when I drive outside. Does any one else notice this? Is there a way to turn on daytime running lamps? I feel much better when these are activated in my other cars. I am suprised this car doesn't have it considering how new the car/model is, Nissan always offering cutting edge autos as well as the technology and layout of the Z. Can anyone help me with this??
Thanks
Jeff
Old May 17, 2008 | 12:22 PM
terrasmak's Avatar
First there are no daytime running lights , and second the gauges are always lit up.
Old May 17, 2008 | 12:38 PM
scharky's Avatar
scharky
You can adjust the brightness of your guages as well, using the buttons on the left hand side of the dash. Turning up the brightness during the day will show you that they are on in the light.
Old May 17, 2008 | 03:36 PM
johns350's Avatar
johns350
And you can always adjust the brightnes..
Just as the Owners Manual states
Old May 17, 2008 | 07:08 PM
Nunzzio's Avatar
Nunzzio
Thanks....I had the gauges up all the way on brightness but did not know that the dash is lit at all times. It is too bad that there are no daytime running lights
Jeff
Old May 25, 2008 | 12:30 PM
avandss's Avatar
avandss
Jeff
it took me 35min to install drl, cost about 5$
pm if you want drl, i had to do it since its a must in canada
Old May 26, 2008 | 11:52 AM
dsmZ's Avatar
dsmZ
Jeff
sooo why dont you just turn the lights on??
Old May 26, 2008 | 12:04 PM
GA_VQ's Avatar
GA_VQ
Cause hid's are expensive to replace!
Old May 26, 2008 | 12:12 PM
wheat's Avatar
wheat
HIDs last forever , you MIGHT have to replace ONE set the entire time you own your car. JMO
Old May 26, 2008 | 12:23 PM
GA_VQ's Avatar
GA_VQ
Don't be so sure of that...
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
