recommended Amp setting
Old Dec 13, 2004 | 02:45 PM
dannichols's Avatar
dannichols
Default recommended Amp setting
Does it make more sense when using good quality components speakers (MB Quart PCE or B/A) and a low power amp (50W X4 RMS), to simply bridge the power to the front components and forget about powering the rear speakers? Or bridinging to the front and running the rears from the HU??
Old Dec 13, 2004 | 03:06 PM
newtlicious's Avatar
newtlicious
Anytime you bridge 2 channels into 1 you get more power and more distortion as well. Sending a dirty signal to nice clean components will not help you much. I would buy a nice 2 channel amp and forget about the rear speakers. That way you have more money to spend on great components and a better amp.
Old Dec 13, 2004 | 03:09 PM
dannichols's Avatar
dannichols
Thanks! The problem is the Alpine 4 channel amp (and a lot of other 4x out there) is only 50W x 4.. It is waayyyy underpowered for decent components. I kind of wanted to use my rear speakers for a little fill-in sound but I'll try it without them. I wish someone made a high-quality amp that was lop-sided, such as 150W x 2 + 50W x 2.
Old Dec 13, 2004 | 03:14 PM
southern_info's Avatar
southern_info
Dude dont' B.S yourself just get 1 4 channel amp to run your highs on preferably 700watts which is more than a enough and 1 channel 2000watts mono block amp for your subs. Your probably not going to use more than half of that 700watt amp on your highs, because mines was too damn loud and 2000watt probably RMS (1000watts) would be hell of enough bass.
Old Dec 13, 2004 | 03:17 PM
dannichols's Avatar
dannichols
dammit I hate car audio! I ended up replacing my old amp when I put in a 12" MBQ Sub..now I gotta trash this 4-channel amp too. Does this upgrading ever end!!!!!!!!!
Old Dec 13, 2004 | 03:40 PM
SB Track's Avatar
SB Track
Check out the JL Audio 450/4 Amp. I believe it is 150rms fronts and lower rears. I plan on using it when I take out all the speakers and put in MBQuart Q-Line fronts and some decently high quality filler rears.
Old Dec 13, 2004 | 03:47 PM
stu46's Avatar
stu46
There's Xtant X604
Specifications
Number of Channels 4
Watts per Channel 4 Ohm 4 x 75
Watts per channel 2 Ohm 4 x 150
Bridged Mono at 4 Ohm 2 x 300
or MTX Thunder 6304
Power 14.4 VDC
2 Ohm Load 165 w x 4
4 Ohm Load 90 w x 4
Bridged 4 Ohm Load 325 w x 2
dannichols's Avatar
dannichols
wow..that looks nice. What's up with JL's method of describing wattage though? 1.5 ohm to 4 ohm?
Anyway, thanks it looks like some manufacturers recognize the different levels needed for fronts/rear.
Old Dec 13, 2004 | 03:48 PM
dannichols's Avatar
dannichols
Do you have that amp Stu?
Old Dec 13, 2004 | 03:50 PM
stu46's Avatar
stu46
That's cause they got the crazy 3ohm w7s.
Old Dec 13, 2004 | 03:51 PM
stu46's Avatar
stu46
No. Ive got 3 Xtant 1.1i and 3 Xtant 3.1. They also have a 400.4 which is 50x4 but is more like 80x4. All of their amps are very good and very underated.
Old Dec 13, 2004 | 04:05 PM
southern_info
For good prices on amps and subwoofer...etc...go to www.millionbuy.com
Old Dec 13, 2004 | 05:12 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
dont forget about thePhoenix Gold Xenon 200.4
200 watts rms x 4 1-4ohm
that amp kick ***
JL uses a specific power supply that adjusts itself to product the same power at any ohm load. JL amps like phoenix gold Xenon amps are not the traditional Mosfett amps. The amp architecture is like that of high end home audio amps. Nobody makes these type of amps because they cost so much. As it stands, Phoenix Gold makes the cheapest and the best amps of this type.
I say best because the signal to noise ratio is the best on the market, even amoungst 10,000 dollar prototype amps.
Old Dec 13, 2004 | 05:30 PM
stu46's Avatar
stu46
Forgot about them PG. Don't know how that happened.
Old Dec 13, 2004 | 05:33 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
Old Dec 13, 2004 | 05:43 PM
stu46's Avatar
stu46
I see you changed your avatar and sig.
Old Dec 13, 2004 | 05:51 PM
Ahsmo's Avatar
Ahsmo
Imakecopies
had to go with the ostentatious look for a while
kyin
Oct 15, 2015 05:54 AM
