Can someone explain ohm's to me?
Old Jun 2, 2005 | 02:14 PM
Santacruzslick's Avatar
Santacruzslick
Veteran
Default Can someone explain ohm's to me?
Ok, I'm looking to add more bass to my stereo but all this stuff about ohms is confusing the hell outta me. Like, an amp. is putting out twice as many watts at 2 ohms than it does at 4 ohms. How do I know if I'm running at 2 or 4 ohms?
Old Jun 2, 2005 | 02:24 PM
brendone's Avatar
brendone
Check this out.
Ohm's Law & Car stereos
Old Jun 2, 2005 | 02:28 PM
Santacruzslick
Veteran
If it's possible I think that site confused me more. LOL
Old Jun 2, 2005 | 03:01 PM
ken350z's Avatar
ken350z
It's more complicated than this but this is the basic idea...
V = volts
P = power in watts
R = resistance in ohms
Cars only have a small amount of volts available, about 12v. This is why speakers intended for cars have very low ohms.
P = (V x V) / R
For a 8 ohm speaker:
(12 x 12) / 8 = 18 watts
4 ohm:
(12 x 12) / 4 = 36 watts
Old Jun 2, 2005 | 06:04 PM
Paul350Z's Avatar
Paul350Z
Living in 350Z
An ohm is a measurement of resistance.
A watt is a measurement of power/work.
An ampure is a measurement of current flow.
A volt is a measurement of potential difference (pressure).
As was stated above the car's voltage is low so in order to get more work done current flow is increased. Put it another way using water - in order to fill a bucket with water you can use a high pressure hose (high voltage) and fill the bucket very quickly with very little flow (amps) OR you could use a very low pressure hose that was huge in diameter and fill it very quickly with lots of water flow (electrial current).
Old Jun 3, 2005 | 05:15 AM
Deceit's Avatar
Deceit
Some more good reading: http://www.the12volt.com/ohm/ohmslaw.asp
Old Jun 3, 2005 | 06:18 AM
Santacruzslick
Veteran
Wow...that's really...technical. My mind can't take that stuff during the summer. LOL
Can someone just tell me what I have to do to get 2 subs to run at 2 ohms? That's what I was trying to figure out.
Old Jun 3, 2005 | 07:13 AM
LS350Z's Avatar
LS350Z
Charter Member #56
Either get 2 4 ohm Single Voice Coil subs (SVC) or get 2 2ohm Dual Voice Coil Subs (DVC). 2 4ohm DVC subs can not yeild 2 ohm amp loads..
Old Jun 3, 2005 | 07:23 AM
Santacruzslick
Veteran
Ok cool. That helps a lot. Now I know what I need to look for.
Old Jun 3, 2005 | 12:50 PM
Kaitain's Avatar
Kaitain
It's all pretty simple really. You see electronics work using smoke, if you let the smoke out they won't work.
Old Jun 3, 2005 | 01:19 PM
2004z's Avatar
2004z
Sleeps in 350Z
Look at the instruction manual. If you go to JL's site, they'll tell you exactly how to wire their subs to get specific ohm figures.
Also, don't just go out and buy any sub. The sub must be designed to work at 2 ohms. i.e. you can't turn a 4 ohm sub into a 2ohm sub.
Old Jun 3, 2005 | 01:21 PM
Badfish25's Avatar
Badfish25
this helps with wiring. http://www.edesignaudio.com/wiring.php
Old Jun 3, 2005 | 02:27 PM
Santacruzslick
Veteran
My current sub is wired with positives going to positives and negatives to negatives. The second diagram shows it wired the way you would wire batteries together. The + of one side to the - of the other side then connecting the remaining ports to the amp. Is that better than splitting the + and - wires and running only + to + and - to -.
Basically what I'm asking is...from the top 2 diagrams on badfish25's post, which is better for hooking up one sub?
irishguy0224
Sep 22, 2015 06:57 PM
shagz
Jan 5, 2003 05:56 PM
JZC
Jan 3, 2003 06:02 PM
Ricky
Nov 28, 2002 12:54 PM
SKiDaZZLe
Oct 2, 2002 08:09 AM
