Installed Techtom warn 56K
Old Feb 1, 2006 | 01:45 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
Default Installed Techtom warn 56K
Super easy will include pics of install
tools youll need:
Bottle of favorite beer or a couple in my case.
Round file or dremel tool - i used file, let chance for error and excuse to drink more.
To Do
1. pull shift **** off
2. pull lil spacer off
3. Pull boot and plastic piece off
4. Pull up coin tray
5. File Coin tray like so
6. feed male end through hole in back of arm rest where coin tray should be
7. Fish through toward front drop down on left by knee pad
8. tuck up loose wire
9. Plug into OBDII port
10 & 11. Reinstall All pieces and make cover to finish off rest of change area
MI 35th's Avatar
MI 35th
OGPremierMafia
Old Feb 1, 2006 | 01:51 PM
vantage350z's Avatar
vantage350z
nice, i just did the same thing, i used stinger and Heineken.
Old Feb 1, 2006 | 02:17 PM
PCA350z's Avatar
PCA350z
What does the number on there represent?
Old Feb 1, 2006 | 03:00 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
mine was RPM x 10 so 850 RPM...
vantage what di you use to make that plate?
Old Feb 1, 2006 | 03:02 PM
Chebosto's Avatar
Chebosto
nice install picts.. are you just using it for peak hold? how are you monitoring it if its in the coin box?
Old Feb 1, 2006 | 03:17 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
peak hold yes
Old Feb 1, 2006 | 03:46 PM
rockinbboy's Avatar
rockinbboy
Um...I don't get it.
What's "peak hold" and why do you need to monitor it?
Old Feb 1, 2006 | 03:48 PM
MI 35th's Avatar
MI 35th
OGPremierMafia
its the peak number that each hit... like highest rpm you hit or most ign advance.
Old Feb 1, 2006 | 05:55 PM
vantage350z
I cut a piece of thin black plastic and wrapped it in vinyl. The stinger gauge had the transparent red lens on it. The only thing i forgot to do was adjust the voltage before installing it. now it reads about 1.1 volts too low. i gotta rip it out and fix it.
Old Feb 1, 2006 | 06:13 PM
MyV6IsFast3r's Avatar
MyV6IsFast3r
Im such a n00b... WTF is that? Why is it important?
Old Feb 1, 2006 | 06:44 PM
CopperZ's Avatar
CopperZ
It seems no one knows what this thing does, but that’s not the important question here, but the one that’s important is: where are you going to put the change now???? JK nice install congrads.
Old Feb 1, 2006 | 08:09 PM
KPierson's Avatar
KPierson
Dang newbies.....
Peak hold can be used to view the max value a perimeter reached during a set period.
Old Feb 1, 2006 | 08:11 PM
ASTIG_Z's Avatar
ASTIG_Z
Originally Posted by KPierson
Dang newbies.....
Still in the Dark...Please elaborate!
Old Feb 1, 2006 | 11:06 PM
Bubble's Avatar
Bubble
-REPLICA ARMY-
google is your friend if you need help.
http://www.technosquareinc.com/cmx.htm
Old Feb 2, 2006 | 07:22 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
THIS LOOKS LIKE 350EVO's car interior. Thats where i got the techtom from anyway.
Old Feb 2, 2006 | 07:24 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
Peak Hold example
say you are driving and it is monitoring RPM you max out at 7,000 RPM the gauge will remeber the highest RPM you hit was 7,000 and hold that in its memory until erased or higher is hit, or that session is over.
Old Feb 2, 2006 | 08:17 AM
Bubble's Avatar
Bubble
-REPLICA ARMY-
Peak Hold example
so this is just for fun, displaying only? no performance gain right?
Old Feb 2, 2006 | 10:28 AM
MI 35th's Avatar
MI 35th
OGPremierMafia
no performance gain just monitoring functions, water temp and AFR are my big two. and its fun to see your peak speed.
Gruppe-S
Body Interior
13
May 16, 2016 10:42 PM
