Anyone use this ipod adapter?
Old Feb 19, 2006 | 01:42 PM
Mr_Drifter's Avatar
Mr_Drifter
Default Anyone use this ipod adapter?
Seems like it should work great...but I would like to hear from someone on the quality of this product first before I order.
http://www.discountcarstereo.com/detail.aspx?ID=701
Old Feb 21, 2006 | 04:38 PM
dgz32's Avatar
dgz32
I emailed them about this very same interface, asking if the AUX-NISSv2 works for '03 Zs, shouldn't this work also. I was told that it *may* work on an '03 non-bose, but was only listed to work on the '04-'06 (as the site indicates). So since you have an '06 you should be good to go.
You could always contact them to comfirm, though.
|dg
Old Feb 21, 2006 | 06:00 PM
Mr_Drifter's Avatar
Mr_Drifter
I placed my order yesterday, so when it arrives, I will hook it up and hope for the best
Old Feb 22, 2006 | 07:26 AM
dgz32's Avatar
dgz32
Cool. Let us know how it works out. If you wouldn't mind, take a pic of the back of your HU while you have it out. I'm curious to see if it's any different than the '03.
|dg
Old Feb 25, 2006 | 06:30 AM
quietcoolone's Avatar
quietcoolone
Thumbs up Pa11NIS works in the 06
My best friend Lisa went out and purchased an 06 350Z (nice car), and wanted to connect one of her many iPods to the stereo but did not want to use an FM Modulator-- we called the dealer and found that there was nothing available--, so we went to Google and typed "Nissan ipod adapter"--- and boom, there is was. The same product (PA11NIS) mentioned in this post was available from discount car stereos in Virginia--- we emailed to see if we could drive there and have it installed (i was anxious for a 110 mile journey), but was told that they are a mail order company--- but could deliver the part to NC by the next day and we can install it or have a local shop install it. She placed the order last week Thursday and the part was delivered to NC on Friday-- On Saturday we took the dash apart (what a pain), and connected the 12-pin connector.. but the thing would not work.. we emailed tech support and surprisingly they replied in just 10 minutes and explained that the 10-pin power connector must be disconnected from the radio and plugged into the interface and to connect the male 10-pin back into the radio. We did, and music began to play ---- this gadget works...anyone reading this should definitely check it out. By the way... she opted for direct mode instead of playlist mode.
Notes:
1. In retrospect-- the install issue was out fault.. the online diagram explain the process but we failed to read first.
2. The 10-pin radio connector is a PITA -- use caution and be patient.
3. Read the manual before installing-- this could save time.
4. Customer support from reseller was gr8 (even on Saturday)
5. Have a beer after your done--- working on a new car requires your full attention.
Good luck to all you Z's !
Old Feb 25, 2006 | 06:52 AM
Mr_Drifter's Avatar
Mr_Drifter
so yeah, I finally got it hooked up and it works great. I'll post pictures later on
Old Feb 25, 2006 | 09:20 AM
nanook's Avatar
nanook
Default working in a 2003?
if anyone gets this to work in 2003 non-Bose let me know.
Old Feb 25, 2006 | 05:45 PM
quietcoolone
I'm not a Nissan expert, but why would it not work in the 03-- from what I've seen those radio look the same---- then again the software used in the 03 may be different, but with no other options i would give it shot!
Old Feb 26, 2006 | 10:58 AM
ESPO 774's Avatar
ESPO 774
will this ipod adaptor work with an 06 touring?? I heard somewhere that the sat. ready headunits are different, in that they dont have the input in the back. is this true? i was told that I need the AAI-NIS to hook up the ipod to a sat. ready Z. I would rather use the PA11-NIS listed here on discountcarstereo.com. any help would be appreciated.
Old Feb 27, 2006 | 10:37 AM
quietcoolone
Say, did you read my post? 2006 350Z--- installed and working...all these radio has sat option-- you may or many have it installed by the dealer, of you don't have it you can use the PA11-, if you do you must disconnect it.. it's that simple, this is not rocket science.
be kewl.
Old Feb 27, 2006 | 11:03 AM
ESPO 774's Avatar
ESPO 774
so if my 06 came from the factory with sirius radio, that means the sat. radio is plugged into the 12 pin port in the back of the radio? So all i have to do is unplug the sat. radio from the port and plug in the ipod adaptor??? thanks for your help, i just want to get it right.
Old Feb 27, 2006 | 04:32 PM
quietcoolone
Thumbs up
you got it right this time...lol.
I don't think we should have to make a choice between SAT and iPod-- hopefully these folks will find a way to combine them-- meanwhile you can use the PXNI aux input which lets you keep the factory SAT, but keep in mind that the PXNI is not an iPod interface but an auxiliary audio input-- which mean you can listen to your ipod but you can't control or charge it-- well charging is possible with the pxp01 but again no controls from the radio.
Old Mar 4, 2006 | 07:24 PM
barclayloftus's Avatar
barclayloftus
ok. so i got this and installed it this morning... but it sounds like hell... there's NO bass... how's it sound for everyone else? :-\
m_0g
Jun 3, 2021 10:05 AM
Dsowe
Feb 17, 2021 10:38 AM
jlb
Oct 15, 2017 05:10 AM
seagrasser
Oct 11, 2015 03:27 PM
