Replaced Head Unit (WOW)
Old Mar 13, 2006 | 04:50 AM
ralphpolanco's Avatar
ralphpolanco
Default Replaced Head Unit (WOW)
I'm now a believer. I knew the Bose system sounded crappy, after finally replacing just the head unit (Kenwood K5028), HOLLY CRAP, what a difference.
Thanks to all you guys that help.
During replacement the Check Engine Light came on, any help with resetting it.
I'm going to look at other threads.
Old Mar 13, 2006 | 05:03 AM
SungNamZ's Avatar
SungNamZ
Give it a couple of days and it should go away! I had the problem along with some others that have posted lately. I suspect it has something to do with disconnecting the harness to the HU and brake.
Old Mar 16, 2006 | 03:08 AM
ralphpolanco
Default Engine Service Light
Yeap, a couple of days later, light is out.
Thanks for the feedback.
Old Mar 16, 2006 | 06:03 AM
SungNamZ's Avatar
SungNamZ
Great! I had the same results "(WOW)" with the Bose system when I replaced the HU with the Eclipse AVX2494, plus harness and 4ch adjuster.
Old Mar 16, 2006 | 07:11 AM
Nazar's Avatar
Nazar
Now all you have to do is get a nice amp and some components.
Old Mar 17, 2006 | 05:26 AM
Old School's Avatar
Old School
Shift_Boost
Glad to hear it guys. I just recently bought Infinity Components, Infinity Coaxils, Phoenix Gold ZX475, Alpine DVA-9860, Farenheit screen, Image Dynamics ID8s, Memphis 1000D. I already have the memphis and Image dynamics installed. Just waiting on my alarm to go in before I throw the rest of it in the car. Looks like I have alot to look forward to. Congrats!
Old Mar 17, 2006 | 05:56 AM
[]V[]addog's Avatar
[]V[]addog
You just replaced the HU? you didnt; change anything else and you got that effect?> I thought I heard something about the speakers needing differnt amperage, needing some harness.... all this stuff.
please fill me in.
thanks
Old Mar 17, 2006 | 03:06 PM
Jun's Avatar
Jun
please fill me in.
thanks
I replaced my stock headunit for a Pioneer unit.
The difference in sound quality is like night & day.
I can't believe I waited 2 years to replace it...
Old Mar 17, 2006 | 07:56 PM
southern_info's Avatar
southern_info
Do you get more power out of the bose subwoofer with just changing out the HU?
Old Mar 17, 2006 | 08:40 PM
ZPatrick's Avatar
ZPatrick
+1
Old Mar 17, 2006 | 08:58 PM
pinoyhero's Avatar
pinoyhero
+2
Old Mar 18, 2006 | 04:46 AM
SungNamZ's Avatar
SungNamZ
+3 But, the shop that installed my Eclipse also added a "4ch Adjustable Line Output Converter".
Old Mar 18, 2006 | 06:39 AM
pinoyhero's Avatar
pinoyhero
FOr HU replacement alone, what deck gives the best bang for buck?
Old Mar 19, 2006 | 08:01 AM
ralphpolanco
Default Just Head Unit
I will confirm, Kenwood MP5028, it does sound 100 times better than the Bose Head Unit but changing the speakers and Bose amp will make it even better. I.e. I still have the volume flux issues, not that bad though. I think my next step is to remove the sub and the bose amp.
RP
Old Mar 19, 2006 | 05:49 PM
[]V[]addog's Avatar
[]V[]addog
so, when you replace just the HU. all you need is the harness and face plate and your good to go ?
Old Mar 21, 2006 | 05:26 AM
ralphpolanco
Default Receiver and Harness
Yeah, I ordered it from Crutchfield and they sent me everything, harness and adpater to fit in 350z. Get this, they even sent instructions on how to replace the speakers even though I did not order any.
I will admit though, it does sound a 100% better with just replacing the receiver. But my next step is to get rid of the Bose amp. It still does some funky sound adjusting to the stock speakers.
No rush though.
Old Mar 21, 2006 | 09:04 AM
Strife350z's Avatar
Strife350z
do aftermarket HUs weight less than the stock BOSE?
the BOSE is craptacular, and I've been eyeing a replacement for a while... but it'd be a bonus if ripping it out yields a weight-savings in addition to sound improvement
Old Mar 21, 2006 | 09:06 AM
[]V[]addog's Avatar
[]V[]addog
No rush though.
like what?
Maybe a dumb question but any reason you couldnt just hook the HU right up to the speakers instead of gogin thru the bose amps?
Old Mar 21, 2006 | 10:10 AM
ralphpolanco
Default Maybe
You are probably right. I just spliced the harness that was sent and it works. Then I noticed, as I looked at the wiring diagram that I found here, that the Bose Head unit went to the amp and the amp to the speakers, sub and a microphone, which adjust sound levels. Not as noticable but there are times when the sound does fluctuate.
So to answer your question I probably could have bypassed the amp. As a matter of fact I may try that just by removing the wires from the amp and jumping them together. It will be a straight shot to the new receiver.
Just to add on the post about weight, Really I don't think it makes a difference.
kyin
Oct 15, 2015 05:54 AM
350z82
Oct 1, 2015 06:25 PM
