Push button Start
Old Mar 21, 2006 | 03:58 AM
  #61
gringott's Avatar
gringott
Originally Posted by Peppie
Looks also very nice. What is the price for the Z8 button?
You don’t have to use a large washer to mount it into the existing hole.
Dealer quotes here in the US were over 100 dollars, so a friend got it for me through a wholesale connection for considerably less.
Old Mar 21, 2006 | 04:58 AM
  #62
Donny_b's Avatar
Donny_b
I ordered one from a Honda dealer, and had a Local Speed Shop install it. I still have to use my key to turn the ignition. To tell you the truth I forget to push the button most of the time, but it looks cool, at least to me......db
Old Mar 21, 2006 | 05:57 AM
  #63
Peppie's Avatar
Peppie
Wink
The same happens to me in my convertible. I have to use the key to turn ignition on and I often use the key to start instead of the button. But it is a cool option.
Otherwise could cut one wire from the starter switch. But then you can only use the button. It is also an compromise, because you still need the key. But a nice added feature for a low price.
Old Mar 22, 2006 | 07:35 AM
  #64
w8lifter21's Avatar
w8lifter21
Well, if you have a remote start, you already have a key "in the ignition" due to the immobilizer bypass, or you could install one for this mod. Install a rocker switch on a relay that turns the ignition on and then hit the start button. The steering wheel unlocks when you remote start the car...
Old Mar 22, 2006 | 08:00 AM
  #65
deezz's Avatar
deezz
You have any pics?
Old Sep 13, 2006 | 01:02 PM
  #66
james840a's Avatar
james840a
Old Sep 30, 2006 | 11:49 AM
  #67
CESAROTORRES's Avatar
CESAROTORRES
Default Lexus 2007 Es350
Originally Posted by evobunny
also my brother has the brand new lexus IS350, you dont have to have the key in to use the push start. he keep his key in his pocket the whole time. dont even need to take his keys out to open the door. It has what you could call true keyless entry. just get close to the car, and it unlock. Just like sl500
The Lexus ES350 also has the same features as the SL500
Cesar
Old Sep 30, 2006 | 12:26 PM
  #68
702Fairlady's Avatar
702Fairlady
Originally Posted by Bubble
even with the new Covette, you still need to put your key in. If not, anyone can get in, push and drive off your car.
This is not true. The new corvettes use a wireless key fob that when in range allows the car to start. You can hop in with the key fob in your pocket and jump in and start, no keys needed. The new Cadillac CTS are also using the same intelligent key fobs
Old Oct 1, 2006 | 02:07 PM
  #69
peter2oo2's Avatar
peter2oo2
cool stuff.
Old Oct 24, 2006 | 08:58 AM
  #70
johnfilice's Avatar
johnfilice
If it was indeed like the lexus in which the key never leaves your pocket, i would be all over it, seems like a hassle to have to put in the key, and turn it, then push the button? why not just turn the key another quarter turn, and there you go, started car.
Old Oct 24, 2006 | 09:42 AM
  #71
seatown z's Avatar
seatown z
i would like to install a push button, but instead of using the regular button...i would make it look like a factory button, or a button in the dash that i don't use...that way it would be stealth...so to start the car you would need your keys in the ignition and push the stealth button...great security feature i think...
Old Oct 24, 2006 | 05:18 PM
  #72
farobaba's Avatar
farobaba
how much to get it installed?
sherm
Apr 11, 2020 05:21 PM
Dymsi
Sep 29, 2015 11:32 AM
