please help now window wont roll up after install
Old Apr 16, 2006 | 08:39 PM
ARMSTRONGARMS's Avatar
ARMSTRONGARMS
Default please help now window wont roll up after install
I dont know what the hell is going on, i just installed diamond audio hex's in the doors wired up 2 amps, a 2/3 way electronic crossover. got everything finally done. my passenger window wouldnt roll up? i recycled the key a few times and got it to roll up, but seeing if it was working, it will roll down but not up. also the door lock switch's wont work, and my drivers window is not going up after shuting door, GOD someone help me, im going to the branson show this thursday? i have to find whats wrong, any ideas. ive searched the threads but cant find what im looking for please help,please.
Old Apr 16, 2006 | 08:45 PM
dmzx's Avatar
dmzx
Default Did you...
Did you unplug the wire harness from the door to the chassis? If you did, then you may have bent a few of the tiny connectors that are inside the plug when you pushed it back together and the things that you describe aren't connected.. let me know...
Old Apr 16, 2006 | 08:47 PM
ARMSTRONGARMS
yes if your refering to the door loom harness's, but why would the window go up once, rolls down fine but not go up? still same thing you think. i had a hell of a time getting that pass, side back on, theres zero room.
Old Apr 16, 2006 | 08:53 PM
dmzx's Avatar
dmzx
Default Theres your problem...
I did the same thing, and found that I bent a few wires, and door locks wouldnt work and windows wouldnt roll up. Carefully bend the ones back to straight, they have to be perfect, and very gently push the clip back together. it might take a few times. What ever you do, dont break any off. Be very gentle with them, and pry them with a tiny screwdriver. Good luck...PM me if you need any more help.
Old Apr 16, 2006 | 08:59 PM
ARMSTRONGARMS
i just took off pass side and all the pins look fine?
dmzx's Avatar
dmzx
Default Also...
As always with an install problem, check all your related fuses, you may have shorted something when you rolled it up once then down..
Old Apr 16, 2006 | 09:00 PM
ARMSTRONGARMS
any tricks for getting the pass in easier, that side is a *****?
ARMSTRONGARMS
but see the thing is it will roll down now? just not up?
Old Apr 16, 2006 | 09:06 PM
dmzx's Avatar
dmzx
Default ...
That sounds like a switch problem. You might have to take the door panel off again and check the switch. Also make sure the drivers side is ok too, because it also has controls for the passenger side window, and locks.
Old Apr 17, 2006 | 06:53 AM
jdohman's Avatar
jdohman
Let me ask you this.. When you shut the door. You roll down the window as you say and it will not come back up. If you hold the switch and hit the door panel where the window motor is. Will it come up then.
Old Apr 17, 2006 | 07:02 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
i concurr that sounds like bent pinns in the molexplug on the chasis wher ehte stock wires pass through...
pull both the driver and passenger side, on most cars, if soemthing is messed up wtih the driver side, it can affect the passenger side as well...pull out hte FEMALE part of the plug , the side thats inside the car, and carefully shine a light on them to see if you have any bent pins...i am putting all my money on bent pins, and you have to carefully put them back in place...
i have dont this on one occassion a few years ago to another car, took me an hour to correct the problem, but you have to be careful and make sure the pinns are going in before pushing, cuase you bend it a few times too many and if one of htem snaps, then you are in trouble
b
Old Apr 17, 2006 | 08:39 AM
ARMSTRONGARMS
thanks for the help guys. problem fixed, i pulled drivers side and there was one bent pin. i thought for sure that would be it. but it ended up being the pass side. the white portion of the plug that is in the interior. it has a catch on the top of it. it wasnt stuck or catching and not allowing enough contact? anyway fixed now, whew what a PIA.
Old Apr 17, 2006 | 09:08 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hehe, good to hear...i bet you have some cuts and scraps on your hands? each time i run new wires into doors of Gs and Zs, i get a lot of cuts hehe, i should throw in bandaid costs into install sof Gs and Zs from now on lol
b
Obadabot
Jun 18, 2023 11:31 PM
