Back up Camera and Car PC
Old Jan 21, 2007 | 08:53 PM
zdero's Avatar
zdero
Default Back up Camera and Car PC
I am building my car pc and I ran into a slight problem. I want my backup camera to come in automatically when i put the car in reverse. I have read where some people use the reverse lights as power for the camera to accomplish this. However, I would also like to be able to turn the camera on while driving. Does anyone know how I can make the camera come on automatically when I put it in reverse, but also be able to turn it on during any time during the drive. I have a xenarc 700tsv that I will be using for a screen.
Thanks
Old Jan 21, 2007 | 09:30 PM
nm3th's Avatar
nm3th
You'll need to hook up the camera's power line to 2 diodes. One diode from the reverse light; the other to your manual switch. This way, if you manually turn it on, your reverse lights won't come on.
***edit***
added diagram
Old Jan 22, 2007 | 08:36 AM
zdero's Avatar
zdero
Thank you very much.
Old Jan 22, 2007 | 12:48 PM
live2themaxuk's Avatar
live2themaxuk
yep, thats what ive done too :d you know the TSV has auto sensing input on AV2 right so it switches to cam when it senses input?
goodgood. ..
Jamie:d
Old Jan 22, 2007 | 01:12 PM
usmanasif's Avatar
usmanasif
***edit***
added diagram
Thanks for that. I am considering that for my OEM navi and was thinking of adding the switch as well. But I am confused. Wouldn't the reverse lights still come on with the button? Any button's function is always to ground the circuit (power is always on) in all automotive applications so it is completed and the intended accessory turns on. If the reverse light's power and ground are intercepted by the button and then provided when the button is pushed, wouldn't the reverse lights come on anyway? Wouldn't we have to accomplish the desired outcome by tapping the reverse ground only for use with the stick, and leaving it alone for the button, but instead using only its power wire, then creating a new ground circuit just for the button (by using a nearby chassis bolt, for example?).
Please shed some light on that possibility (no pun intended! ), and whether my logic is even correct.
Old Jan 22, 2007 | 01:16 PM
rich harris's Avatar
rich harris
***edit***
added diagram
Great info...Thx.
Old Jan 22, 2007 | 06:31 PM
nm3th's Avatar
nm3th
The reverse lights will not come on when you manually switch on the camera because diode B is not conducting.
Also, because the TCM is sending a +12V signal (through a relay) to the reverse lights, it's easier to just wire it up this way.
The second pic is taken from a g35 wiring diagram and it shows that the reverse lamps' signal is +12V, not ground.
Attached Thumbnails Back up Camera and Car PC-reverse-cam.jpg   Back up Camera and Car PC-tcm.jpg
Old Jan 22, 2007 | 09:34 PM
usmanasif's Avatar
usmanasif
Hmm...thanks for explaining that. I may PM you before my install. I have been researching EE sites for relay info and think I have a pretty decent grasp on those
Old Jan 23, 2007 | 11:46 PM
L33TZOR's Avatar
L33TZOR
on the subject.... my 3 series beemer has a feature where when i put the car in reverse, the right hand mirror tilts down to view the curb and then back to the orignal spot when out of reverse. can this be accomplished while on this topic?
im wondering, if all the people who run the backup cameras here, are they really worth it? im installing my carpc as well, and does anyone know if the AV2 auto turn on is also a feature with the new 8.4in model Xenarc?
I was just thinking of a front cam too.
ALSO,... which "color" wire do i tap for the 12v+DC line that powers the reverse. the cam im using, the plug is inside a long 30' cord so if i can splice it in somewhere along the way or at the point the 6mt switches it on that would be so helpful, thanks in advance.
Chris350z03
Oct 8, 2023 07:19 PM
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
Mattg350z
Oct 2, 2015 06:51 AM
RyansZ33
Sep 15, 2015 05:54 AM
