Have a question after my Aftermarket HU is installed...
Old Mar 15, 2007 | 07:31 PM
WIKDWS6's Avatar
WIKDWS6
Default Have a question after my Aftermarket HU is installed...
Here is the story, I bought a Pioneer DEL 8600mp Headunit and had a good local car audio place install it since I didn't have time. I told them it needed an adaptor to work with the Bose system, they said no problem. I get the car back tonight and the system sounds worse then before, so I pull the dash out, no adaptor (PAC ROEM-NIS2). I could not remember the name of the adaptor while I was on the phone with them, but I assumed they would know (I guess not). So I need a little clarification, right now is the aftermarket headunit powering all of the speakers and sub by itself? If I buy the PAC ROEM-NIS2 will it utilize the bose factory amps with the new headunit giving the car better sound than stock? If not I am ready to tear this headunit out and go back to stock. Thanks.
PS I used search but its almost worthless.
Old Mar 15, 2007 | 07:36 PM
kfresh's Avatar
kfresh
The PAC ROEM-NIS2 allows you to utilise the Bose Amplifier. You need this to get the proper signal as the Bose Amp works on non standard voltages.
Otherwise the sound quality will be poor and low.
You can buy it off Ebay for approx. $70.
Old Mar 15, 2007 | 08:23 PM
WIKDWS6's Avatar
WIKDWS6
Yeah, I just bought new PAC ROEM-NIS2 off Ebay, for $41 shipped. I really hope this works, I can't tell you how bad the sound is.
Old Jul 3, 2007 | 06:29 AM
mitsurs01's Avatar
mitsurs01
does anyone have a picture of the harness completely put together with the ROEM NIS2? I have my harness wired up, but I dont know what to do with the white/ red green/ red purple/ red and gray/ red wires. Help would be appeciated!
Old Jul 3, 2007 | 07:31 PM
mitsurs01's Avatar
mitsurs01
nevermind I called PAC and u can use the standard colors or the reds as your positive leads for the speakers.
Old Jul 4, 2007 | 12:24 PM
Seel's Avatar
Seel
Item #120707550 this is what you need from crutchfield.com
Old Jul 5, 2007 | 07:04 AM
Apanther's Avatar
Apanther
this is why u install yourself. just like taking care of your ride, no one will put the time and care that your would. if you dont know how, get with some friends that do. or, build a relationship with a reputable shop. not ccity or bbuy.
Old Jul 6, 2007 | 06:38 AM
mitsurs01's Avatar
mitsurs01
p.s. the Bose system with a quality aftermarket head unit sounds INCREDIBLE! There is absolutely NO need to replace all the speakers. The $70 PAC adapter is well worth the investment.
Old Jul 6, 2007 | 08:07 AM
Seel's Avatar
Seel
Needed? Well nothing is needed. I'm replacing everything except the rears. He's right though after you hook up the right adapter it does sound much better.
Old Jul 26, 2007 | 03:10 PM
Denver350z's Avatar
Denver350z
Does the PAC-AOEM-NIS2 work for the 2006 and 2007 z? Everywhere on ebay says it is for the 1995 to 2005 nissans?
Let me know, I would think it will work for my 2006 but want to get confirmation before I purchase it.
Thanks.
Old Oct 17, 2007 | 01:31 PM
amarokorg's Avatar
amarokorg
The PAC ROEM-1-NIS2 for the 1995-2005 Nissans *does not work* with the 2006/2007 350Z, according to "Jose" at PAC when I called them last week.
His recommendation was to use the OEM-2, which is not plug-and-play, just splicing and making some choices about line levels, etc. Not a big deal if you've done any kind of audio/electronics work before.
That said - Crutchfield doesn't list as needing either for a 2006/2007 350Z. I called and asked specifically, but didn't get much more than "Well, our system doesn't say that it needs it, so we don't think it does". Lots of conflicting info on this one...
I've got a new head unit (Pioneer AVIC-D3) waiting to go into my 2007 350Z w/ Bose, and I'm going to install it first without any converters (such as the OEM-2) to see how it works. If the audio is poor or distorted, I'll pick one up and add it.
Also, on another forum, I got a recommendation to use the pre-amp outputs on your headunit (if yours has them) and connect those to the speaker connections on the factory harness - effectively doing the same thing the OEM-2 is trying to do (provide a line-level signal instead of an amplified one). Not sure if the D3 has them, I may go that route.
- Dave
Mattg350z
Oct 2, 2015 06:51 AM
350z82
Oct 1, 2015 06:25 PM
SharX59
Sep 27, 2015 09:23 AM
