Can't Get Amp To Power Up!! Help!!
Old May 10, 2007 | 02:41 AM
ryan987's Avatar
ryan987
Default Can't Get Amp To Power Up!! Help!!
I'm tryin to install the amp in my 06 in the space where the bose sub would've been. I built a litte rack, and connected everything just right...or so i thought. Also, i did make sure to connect 'remote' and have that 'sub-out ON' selected in my HU.
The amp won't power up. I don't have a voltmeter to test, but i did try just undoing a factory bolt back there, scrapping the paint off with a file and using that as my ground. Didn't work....
Can anyone tell me EXACTLY which bolt/hole i can use to get a good ground???
Or any suggestions??
THANKS!!!!!!!!!
Old May 10, 2007 | 03:57 AM
Lsmith9523's Avatar
Lsmith9523
Where do you have your power supply? Also,,check the fuses in your amp. Sometimes during installation, with wires getting moved around and such, the fuses will pop. Keep us posted,,,
Old May 10, 2007 | 04:01 AM
ryan987's Avatar
ryan987
Power is coming straight from the battery, as show in that sweet tutorial on this site. Fuse from Battery is in tact, fuse on amp is also good.
Connected my ground wire exactly as show in this post...
https://my350z.com/forum/showthread....ht=ground+wire
Post #8 to be exact.... Still no power....WHAT THE HELL AM I DOING WRONG!!!?!?!
...please pardon the frustration. Usually such a simple thing to do.
Thanks again for ur help.
Old May 10, 2007 | 04:13 AM
MUZZY's Avatar
MUZZY
connect your remote wire to a constant 12v and see if it turns on.
Old May 10, 2007 | 04:46 AM
ryan987's Avatar
ryan987
where can i find a constant 12v?
Thanks!
Old May 10, 2007 | 06:18 AM
StreetOC192's Avatar
StreetOC192
sorry for the double post.....why can't i delete one of my own posts on this forum?
Old May 10, 2007 | 06:22 AM
StreetOC192
I would go to radio shack and pick up a $20 volt meter and make sure your remote turn on is supplying power. Also check the power from the battery. Use the same spot you have the amp grounded as your volt meter ground first. If you get a reading, you know the ground is good enough to at least turn the amp on. If nothing, move the volt meter ground around to different spots. If you eventually get a reading, then you know your ground is not good enough and you need to move it.
Here's one:
http://www.radioshack.com/product/in...entPage=search
Old May 10, 2007 | 06:45 AM
THE TECH's Avatar
THE TECH
The battery line is constant power.
Old May 10, 2007 | 07:01 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
a easy way:
if you have battery and ground already hooke dup, and have verfiled that the power wire is getting power and the ground wire is grounded properly.
take a small wire, strip both ends, and connect it between the POWER and the REMOTE terminals. essentially jumping hte remote terminal, if the amp turns on, but normally does not, then you have an issue with your remote wire.
if it does NOT turn on, you either have
1. bad ground
2. bad power
3. bad amp
so you test them one after another, by using an extra wire to go from battery directly to each terminal...thats how you get to what is wrong by process of elimination
b
Old May 10, 2007 | 08:33 PM
ryan987's Avatar
ryan987
Originally Posted by 16psibrick
a easy way:
1. bad ground
2. bad power
3. bad amp
b
WOW!!! you are my hero. Your little trick worked like a charm. My remote connection was the problem. Fixed it!!
Thanks so much for your help!!
sales@czp
Sep 23, 2019 03:30 PM
kyin
Oct 15, 2015 05:54 AM
hulkout
Tuning
Sep 30, 2015 12:33 PM
codek
Sep 28, 2015 03:03 AM
