350z Stock Speaker Location Fitment Guide
Old Apr 16, 2008 | 06:33 AM
sintaxeror's Avatar
sintaxeror
Default 350z Stock Speaker Location Fitment Guide
We seem to get these questions a lot, so lets get all the information together and get this stickied to help people out.
Please post the speaker, whether you were able to fit it or not, and if so, what you needed to mount it. If you used a different method to install a speaker that is already on the list, please post also so that all options can be included in the list.
Alpine
SPR-17S (Type R 6 3/4" components) - fit with 1" spacer
Boston Acoustics
Pro 6.5 - Fit over gutted stock speakers
CDT
ES 620z - Fit with a 1" spacer
EF61-FG - Does not fit, Magnet does not clear window.
Diamond Audio
S600S 6.5" - Fit over gutted stock speakers.
DLS
Iridium - Fit with 0.5" Spacer
MS6A - Does not fit, Magnet does not clear window.
UP6i - Fit with 0.5" Spacer
Focal
Focal 165 VRS - Fit with 1" spacer
Focal 165 K2P - Does not fit, Magnet does not clear window.
Hertz
HSK-163 - Fit with 1" Spacer.
Infinity
Perfect 6.1 - Fit with 1" spacer + 5 layers Dynamat
Perfect 6.1 - Fit with gutted stock spacer and shaved a little out of the inside door panel.
Reference 6010cs - Fit with 1" spacer
JL Audio
JL audio VR 650 CSi - Fit with 0.5" spacer
MB Quart
ESA-216 - Fit with 1" spacer
Phoenix Gold
RSD65CS - Will not fit without some cutting and spacer
Pioneer
Premier TS-D720C 6.75" - Will fit with 1" mdf spacer, or 1/2" mdf + supplied pioneer spacer.
Polk
SR6500 - Fit with 1" Spacer
MM 6501 - Tight fit using supplied brackets (one hole needs to be drilled, use two existing holes).
Rainbow
SLC265.25NG - Fit with 1" Spacer and included ring.
RE Audio
XXX 6.5" - DO NOT fit behind stock door panels. Magnet hits the window, if you space the speaker out far enough it is touching the backside of the door panel.
Rockford Fosgate
Punch P162S - Fit with 1" spacer
Old Apr 16, 2008 | 07:24 AM
16psibrick's Avatar
16psibrick
Simplicity in Sound
hey bud, whcih part did you have the fitment issue with the ms6a just curious i dont doubt that it doesnt fit, but there seems to be members here who have fit bigger midbass drivers than it in their doors, such a infinity kappas, alpine type-Rs and diamond hexes
again, just curious, i personally, obviously hate the stock location hehe, i have done two stock door locations recently, one with UP6 via .5" spacer, one is an iridium 6 with a .5" spacer.
basically all the DLS ultimate spekares, with the hybrid neo motor, will fit with a .5" spacer
Old Apr 16, 2008 | 08:04 AM
Gooey's Avatar
Gooey
I just purchased a set of pioneer components for the front. It has a 2.5" mounting depth. Will it fit without spacers needed? How about the tweeters.
Old Apr 16, 2008 | 08:25 AM
sintaxeror's Avatar
sintaxeror
I couldn't get the magnet to clear the window... I suppose you COULD do it if you moved it all the way to the edge of the mounting hole but its very close.
Old Jun 5, 2008 | 09:23 AM
sintaxeror's Avatar
sintaxeror
bump - added Infinity Perfect 6.1. Thanks KManZ!
Old Jun 5, 2008 | 09:40 AM
BlueBoxer's Avatar
BlueBoxer
Stock location, what's that? Bump for a useful thread. Unfortunately, I had pods the whole time so I cannot contribute much.
Old Jun 5, 2008 | 10:16 AM
fatalus's Avatar
fatalus
JL audio VR 650 CSi components: Woofers fit with a small spacer, tweeters fit perfect in the stock mounting location. No cutting at all and stock look!
Old Jun 5, 2008 | 11:15 AM
sintaxeror's Avatar
sintaxeror
What size spacer?
Old Jun 6, 2008 | 01:24 AM
fatalus's Avatar
fatalus
I dont know actually cause they installed it where I bought the speakers. But from what I saw it could not be more than 1/4 inch.
Old Jun 14, 2008 | 06:39 PM
itsjoshufocker's Avatar
itsjoshufocker
dang. so theres really no way to fit the MS6A? (in stock location, that is)
Old Jun 14, 2008 | 11:03 PM
sintaxeror's Avatar
sintaxeror
It looked like you COULD fit it.. but the clearance would be VERY tight... like... somewhere in the neighborhood of a human hair.
I just shelled out the extra cash for the UP6, which fit EASY.
Old Jul 29, 2008 | 09:42 AM
sintaxeror's Avatar
sintaxeror
Bump..
added Infinity 6010cs, thanks teh215.
added Focal 165 VRS and 165 K2P, thanks Roper215
Old Jul 30, 2008 | 02:23 PM
vnarang's Avatar
vnarang
My speaker is like rubbing with the plastic, I'm hella confused, and I have the Infinity speakers.
Old Jul 30, 2008 | 02:37 PM
sintaxeror's Avatar
sintaxeror
Which infinity speakers? and which spacer are you using?
Old Jul 31, 2008 | 08:31 AM
vnarang's Avatar
vnarang
Infinity Reference 6010cs 6-1/2"/6-3/4" 2-way Component System
I'm using whatever came with the set. I was new to this scene, and I didn't join these forums until AFTER I bought the speakers. Also, I didn't install the speakers. I'll post pictures. I completely f*cked up everything I did. I'm really irritated at myself. I don't even think a spacer was used.
Old Jul 31, 2008 | 10:14 AM
sintaxeror's Avatar
sintaxeror
Well chill out a little and order some Zenclosure spacers, that is what teh215 used. Should be a pretty simple install once you get them. Report back if you have other problems, plenty of people to help here.
Old Jul 31, 2008 | 11:02 AM
vnarang's Avatar
vnarang
I am chill, just telling you how I felt after I found out this information. Just to get it straight, basically the spacer pushes out the 'surrounding' so it doesn't rub, correct?
Old Jul 31, 2008 | 11:15 AM
sintaxeror's Avatar
sintaxeror
Here is a visual for you, these are pictures of my speaker installation
Spacer in place:
With speaker mounted:
So you can see, the purpose is to space the speaker out of the hole so that the magnet doesn't hit the window glass when the window is down.
These were 1/2" spacers, you may need more - I would go with 1" because you can buy them easily and someone else(teh215) has already used them with the same speakers you are using.
Does that help?
Old Jul 31, 2008 | 03:38 PM
vnarang's Avatar
vnarang
Spacer in place:
Does that help?
Are you recommending spacers for the front speakers or rear speakers? Because I'm having trouble with the rear speakers; they are rubbing against the plastic and look really off. I will get you pictures. It may be depressing.
Old Jul 31, 2008 | 03:49 PM
vnarang's Avatar
vnarang
Basically, the part where the arrow is, that's where it is rubbing against the plastic and creating nasty noises.
Also, is it recommended to get rid of the rear tweeters, and if I do, is it possible to patch it up?
