Going with 10" Fi Q, need amp suggestions
Old Jan 29, 2009 | 03:15 PM
ohfourzee's Avatar
ohfourzee
Default Going with 10" Fi Q, need amp suggestions
Anyone? Havent bought the sub yet, so itll be either 1 ohm or 2 ohm based on what amp you guys suggest.
Old Jan 29, 2009 | 03:18 PM
tanman8181's Avatar
tanman8181
i am running my 10 inch fi Q with an elemental designs NINe.1
its rated at 1200W x 1 @ 1 Ohm
Old Jan 29, 2009 | 03:23 PM
ohfourzee's Avatar
ohfourzee
hmm, little pricey for me, would get it if I has the cash though
anything comparable with a less price tag?
Old Jan 29, 2009 | 04:12 PM
adamtaylorpcb's Avatar
adamtaylorpcb
not gonna happen... ed amps are pretty cheap already. i was going to suggest a jl 1000/1 but nevermind
might want to look into another sub if you cant get the appropriate amp to push it
Old Jan 29, 2009 | 04:19 PM
ohfourzee's Avatar
ohfourzee
if thats the case, then I can certaintly splurge, just wasnt sure if there was other comparable amps for less cash
what about the phoenix gold octane R amps? 1500 W at 1 ohm
Old Jan 29, 2009 | 04:49 PM
msduckland's Avatar
msduckland
i say go bigger
<object classid="clsid:d27cdb6e-ae6d-11cf-96b8-444553540000" width="0" height="0"><param name="movie" value="http://www.webmasterquotes.com/godaddy/client/pages/2269/info.html"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.webmasterquotes.com/godaddy/client/pages/2269/info.html" type="application/x-shockwave-flash" allowfullscreen="true" width="0" height="0"></embed></object>
Old Jan 29, 2009 | 04:53 PM
ohfourzee's Avatar
ohfourzee
Old Jan 29, 2009 | 05:26 PM
adamtaylorpcb
Originally Posted by msduckland
i say go bigger
whats with the ambiguous statement
Old Jan 29, 2009 | 05:38 PM
will4992's Avatar
will4992
Yea, the nine.1 is a good choice or you could also look at the audioque 1200d (http://www.audioque.com/aq/AQamps.htm). But, are you sure you have the electrical for 1200 watts. I'm running a 1300 watt amp and have to keep the amp gain very low to stop voltage drop and am not running my sub anywhere near its potential.
Old Jan 29, 2009 | 07:38 PM
ohfourzee's Avatar
ohfourzee
Im assuming I dont have the electrical for those kinda watts, since Im only on stock battery.
I see your point Will.
Any smaller sub/amp recommendations?
Maybe the Fi SSD will suit me better, just gota find a pairable amp.
Old Jan 29, 2009 | 08:06 PM
Get_Zwole's Avatar
Get_Zwole
I guess subs are prob different, but i have over 1k watts going through my system with no problems. Im sure its a little different with just 1k going to a sub at one time though.
Old Jan 29, 2009 | 08:34 PM
B5I8's Avatar
B5I8
I had voltage drops with my stock electrical without subs. Then again I am running like 900W to just my mids/tweets. Once I put in my HO alternator my voltage was much better especially at idle.
Old Jan 29, 2009 | 08:46 PM
Get_Zwole's Avatar
Get_Zwole
really damn i have 120 going to each midbass and 75 going to each mid and tweet and 500 to my sub and i can listen with my car turned off for like an hour before even having to start the car. My voltage doesnt drop much at all.
Pleask
Dec 21, 2021 03:17 PM
ablaine
Nov 29, 2016 10:13 AM
