My $100 like OEM fit NAVIGATION setup
Old Sep 12, 2009 | 08:55 AM
  #121
quakerroatmeal's Avatar
quakerroatmeal
I wish I had the 03 cubby hole.
Old Sep 12, 2009 | 05:53 PM
  #122
06blueZ's Avatar
06blueZ
does anybody want to seed the OCN8 software? I have a demonoid account even and it's not on there anymore that I can find.
anyone have an FTP site or something that I can get a copy of it?
Old Sep 12, 2009 | 06:11 PM
  #123
06blueZ's Avatar
06blueZ
nevermind, I think I found a copy... really 1.4 gigs? hope this is all I need...
Old Sep 12, 2009 | 07:08 PM
  #124
chrisjersey06's Avatar
chrisjersey06
I'm making my girlfriend buy me one and she's taking my Garmin Nuvi (windshield suction mount FTL). Thanks to the OP and everyone who has contributed to this thread!
Old Sep 12, 2009 | 09:49 PM
  #125
jtabraham's Avatar
jtabraham
Originally Posted by o2sys
No i'm not using V1.64, you dont need to upgrade the software.
Thanks!
Have you ever had any issues with the device not recognizing the external antenna? I thought I just wasn't getting signal, but now in the OCN8 program, it says the antenna device is not found. Hmm...wondering if I got a faulty external unit.
Old Sep 13, 2009 | 08:13 AM
  #126
chrisjersey06
Also, can you search for restaurants, entertainment, gas stations, etc, like on a Garmin? That's mainly what I use mine for.
Old Sep 13, 2009 | 09:27 AM
  #127
o2sys's Avatar
o2sys
the gps antenna is exceptionally fast on this unit. It catches signal very fast. All the reviews and I myself noticed how fast the GPS signal is on the Plenio.
Try going under setting in OCN8 and see what baud rate and configurations its at. Try seraching for GPS signal in the program as well. Then it should detect the antenna.
Yes you can search restaurants, entertainment, gas stations, etc, like on a Garmin. Its all in the POI (Point Of Interest) database. But personally I suggest you only keep POI of states you will go to. It speeds up the loading.
Old Sep 13, 2009 | 08:51 PM
  #128
KenndeG's Avatar
KenndeG
Where is everybody putting their receiver units? I tried putting mine behind the actual screen vertically and using the magnet to attach it on top of the metal part of the radio, but it picks up no signal...
Old Sep 14, 2009 | 07:47 AM
  #129
06blueZ's Avatar
06blueZ
ok , so I noticed that there is a remote included... do you need the remote for any features that you cannot access through the touch screen? if so, where is the IR receiver? did you guys add a hole somewhere for the remote to work?
also, on some sites it lists a feature of a built in fm modulator, is that true?
Old Sep 14, 2009 | 07:53 AM
  #130
mw9's Avatar
mw9
Originally Posted by jtabraham
Thanks!
You have to go under the settings button and set up the GPS antenna. You just have to check the box.
Old Sep 14, 2009 | 08:48 AM
  #131
burner's Avatar
burner
To answer a couple of questions:
I mounted my antenna right behind the gauge cluster. I just popped up the plastic piece behind it, and routed the wire. There is a nice little pocket right behind the tach that it fits perfect in. Signal goes right through the plastic.
You have you set up the antenna the first time you run OCN8. Just set it for autodetect and it will pick it up.
You can use the remote to do just about anything with the nav unit, but when the screen is mounted in the factory location, the IR sensor is blocked, rendering the remote useless.
There is a built in FM modulator. You can set what station it broadcasts to in the main settings on the Plenio.
Old Sep 14, 2009 | 08:54 AM
  #132
o2sys's Avatar
o2sys
You can buy a IR repeater to use the remote. You can also drill a tiny hole on the cubby as well. I have done neither.
Old Sep 14, 2009 | 09:00 AM
  #133
burner's Avatar
burner
Yeah, you don't really need the remote with the touchscreen.
Old Sep 14, 2009 | 09:05 AM
  #134
06blueZ's Avatar
06blueZ
ok thanks guys, i know sometimes remotes are needed to access some settings or features for some things, but if you can use the touchscreen to do everything the remote does, I wont worry about it.
Old Sep 14, 2009 | 09:09 AM
  #135
o2sys's Avatar
o2sys
remote will still work when u put it close to the cubby on the bottom right corner.
Old Sep 14, 2009 | 03:02 PM
  #136
KenndeG's Avatar
KenndeG
I read the how-to on how to take the top gauge cluster piece out...Does the plastic piece pop out without having to take the whole unit out? Where would you pry/pull?
Old Sep 15, 2009 | 07:54 AM
  #137
jtabraham's Avatar
jtabraham
Yep...I'm an idiot. That was my problem.
So far, I like the unit, especially with OCN8. It loads and calculates routes very quickly.
Old Sep 15, 2009 | 10:09 AM
  #138
o2sys's Avatar
o2sys
There is a lot more you can do to OCN8, like backgrounds, custom themes, and even change the arrow to a 350z! But for me i like clean oem things so i kept is simple.
Old Sep 15, 2009 | 10:53 AM
  #139
bigcloud's Avatar
bigcloud
Could somebody post a good link for a OCN8 download? Unfortunately I bought the 3000 about a year ago, and put it in my (03) cubby. It looks good, but not as good as the 2100. I still would like to use the OCN8 though.
Old Sep 15, 2009 | 03:31 PM
  #140
06blueZ's Avatar
06blueZ
nevermind! found the file I need..
