6.5 subs for the back?
Old Aug 28, 2009 | 10:07 AM
KnighTT's Avatar
KnighTT
Default 6.5 subs for the back?
I had an interesting idea.
I finally have my DDX812 coming, and I want to get the rest of the sound right for this unit. I have Focal comps. in the front, and I was thinking about replacing them with Infinity Kappa Perfect 6.1's and putting the Focal woofers in the speakers slots behind the seats. Then run a small 2 channel amp for the fronts, and a sub amp to put all the bass into the 2 6.5's in the back.
I just dont want to add a sub box and all the extra weight and all. I want it to sound amazing but I also want to take it to the track without having to remove a sub box and all that jazz.
What do you guys think. Worth it or what?
Old Aug 28, 2009 | 12:19 PM
THEDUKE's Avatar
THEDUKE
You are going to run into a few issues. The first is that the Focal woofers are not really woofers, they are actually more of a midbass/midrange driver. They really are going to have a hard time going below 60HZ at any decent level to produce the low end you need from a subwoofer. They other main factor is that you need the rear speaker location to be sealed, which requires some work. It is actually an open cavity back there where the stock speakers mount, not a good thing for subbass. The last thing is that you stated you want it to sound amazing, it will sound decent at best.
Old Aug 28, 2009 | 07:43 PM
KnighTT's Avatar
KnighTT
Perfect point. I'll just have to put a nice 10 in there and make it look stock.
Is there any kits out there to turn the cubby behind the driver seat to a 10" while making it look really stock and flush. Clean. Out of the way.
I have a 2006 base.
Old Sep 1, 2009 | 10:42 AM
quakerroatmeal's Avatar
quakerroatmeal
Do what I did instead..
Old Sep 1, 2009 | 02:38 PM
Spike100's Avatar
Spike100
^^ Looks nice, but I think KnighTT does not want to fill the space below the strut bar with audio gear (it sounds as though he want to maintain maximum cargo space).
Originally Posted by KnighTT
…I just dont want to add a sub box and all the extra weight and all.
--Spike
Old Sep 2, 2009 | 11:28 AM
quakerroatmeal
I don't think you'll get anything to sound amazing without a sub box..
Maybe a custom 3 way up front without a actual dedicated subwoofer in the rear.
Old Sep 11, 2009 | 03:14 PM
w8lifter21's Avatar
w8lifter21
You could do the under strut box and mount allll the other audio gear in the open cavity under the rear speakers. just run speaker wire to the box and when it comes to hit the track, just unplug the box and go.
Old Sep 11, 2009 | 03:15 PM
w8lifter21's Avatar
w8lifter21
I like that setup. What subs/drivers are those? 6.5"-8"?
Old Sep 11, 2009 | 07:47 PM
quakerroatmeal
They're TB 6.5's...
I wish you could fit 4x8"s there.
I would say a 3-way setup is the best way to go without a dedicated subwoofer
sales@czp
Sep 23, 2019 03:30 PM
Depravity
Oct 1, 2015 04:49 PM
Tochigi_236
Sep 27, 2015 03:40 PM
