will these speakers fit?
Old Mar 12, 2010 | 09:34 PM
bbak11010's Avatar
bbak11010
Default will these speakers fit?
hey all,
I am planning to put
CXS64 V.2 - Image Dynamics 6.5" 4 ohm Component System
for the front doors..
The depth is 3".
I gutted out the stock speakers to use the stock spacers and it still was
too deep hitting the window..
I'm thinking it could probably fit with the stock spacer plus 0.5 mdf spacer.. but Im afraid that it won't clear the door panel.
Does anyone have the same speakers or have tried fitting a 3" speaker?
or will it just not fit?
Thanks in advance,
Old Mar 13, 2010 | 04:07 AM
duro78's Avatar
duro78
I mounted mine directly to the door skin with dynamat in between, it fits plus window is clear
Old Mar 13, 2010 | 04:50 AM
davidc81's Avatar
davidc81
get some door pods and be done with it.
Old Mar 13, 2010 | 07:38 AM
duro78's Avatar
duro78
ddor pods are too pricey but they do give better sound. The stock grilles suck because they cover 60% of the speaker plus the hole is off center
Old Mar 13, 2010 | 07:42 AM
bbak11010's Avatar
bbak11010
yup door pods are way too expensive.
Old Mar 13, 2010 | 08:19 AM
jenner1's Avatar
jenner1
door pods may seem expensive but the sound you get out of them is amazing. Also in the end the cost of door pods is really only a small part of your entire system build, around 15% even on a small system. One thing that can save you some money with pods is by getting the unfinished ones, saves you around 100$ and finishing them is really quite easy. I ended up glassing in spots for the tweeters and then covering them in black lambskin for around 30 bucks in materials. I thought finishing them in leather would be a pain with all curves but lightweight lambskin stretches over all the curves without any stitching required and turns out excellent. Just my 2 cents though, deep speakers are a pain to mount in the doors stock locations and you wont get the sound you paid for from your speakers.
Old Mar 13, 2010 | 01:37 PM
350junkie's Avatar
350junkie
sa-zboi (or something like that) is selling some kicker panels that are setup for speakers. you can find them in the Texas Marketplace. I think the thread title is Lots of parts for sale.
Old Mar 14, 2010 | 03:30 PM
Spike100's Avatar
Spike100
I agree. I think it’s a mistake to buy a quality speaker, and then stuff it into a space where your best result is a muffled sound output.
The stock door mount has significant disadvantages:
  • It’s difficult to fit a speaker that is > 2.5” depth (which eliminates many quality speakers).
  • Even if you can stuff a decent speaker inside the stock door mount, you have compromised sound.
  • The stock door grill is only holes drilled in the door panel, and blocks about ½ the sound.
  • The drilled holes in the door panel are too few, too small, and too far apart (it’s configured that way to maintain the door panel’s strength).
  • The stock “door panel grille” is concave. Speaker covers are flat or convex.
  • The stock door speaker mount angles the speaker incorrectly.
There are plenty of opportunities to waste $$'s when installing A/V stuff, but door pods or "kicks" are a good investment.
--Spike
3vilbunny
Jul 18, 2017 05:10 PM
350z82
Oct 1, 2015 06:25 PM
