SRQ Custom Autosound Stock Subwoofer enclosure?
Old 07-31-2010, 02:42 PM
importdemon5
importdemon5's Avatar
Default SRQ Custom Autosound Stock Subwoofer enclosure?
Has anyone tried the SRQ Custom Autosound subwoofer enclosure for the stock bose sub location? Looks very similar to the Wicked CAS box. Just curious
http://shop.srqcustoms.com/Nissan-35...uot_p_160.html
Old 07-31-2010, 03:16 PM
Xlr82x
Xlr82x's Avatar
I agree, looks real similar to the Wicked CAS box. I am not sure how well this design will sound. The Wicked box doesn't seal up the cavity so the sound is still projected forward, this box doesn't have an opening which means the sound is going to resonate on the thin walls with in the area. May allow for better lows ? Would be interested if someone has a review on this as well.
Old 07-31-2010, 07:40 PM
Paul350Z
Living in 350Z
Paul350Z's Avatar
I have concerns about the thickness of the walls because the woofer pumps a bunch of energy into the cabinet which it must absorb. Think walls would resonate with the vibrations which is a bad thing. A sealed box is a good thing.
Old 08-01-2010, 01:52 PM
importdemon5
ANybody try it?
Old 08-04-2010, 09:09 AM
importdemon5
I know that the stock BOSE box behind the seat is an open box but wouldn't this box be considered a sealed box?
Old 04-21-2011, 09:06 AM
2fasst
2fasst's Avatar
bumpy bump..so anyone tried this???
Old 04-23-2011, 03:32 PM
v-rath
v-rath's Avatar
I posted this in the other thread, but FYI, when you order, you can have it cut to fit a 13tw5, just put that in the comments block when you place your order. They will also put poly fill in the box for free if you also mention it.
I was going to buy the wicked C.A.S, Now I can buy the Vinyl'd door pods and this box for around the same price. = winning. I'll post pictures and video stuff in my other thread next week after I get back from vacation and do my installs.
Old 04-01-2014, 08:06 AM
ohmicide
ohmicide's Avatar
bump, not a lot of info or reviews on these
I would like to keep all my cargo space as possible, not looking for earth shattering bass, most I'll have in there is probably around 300 watts rms
Old 04-01-2014, 09:24 AM
bmccann101
bmccann101's Avatar
its not a great spot. the plastic trim around that area buzzes violently.
Notoice i didnt say rattle.. its not a rattle.. its panel movement due to a large amount of force... its far more like trunk buzz and was highly audible.. I also didnt like the path length.. ie, subs in the very rear sound FAR better.
In a convertible, itd be great, but in a coupe its no good. SOld mine as fast as i could.
the visible flange is 1/8 inch mdf/masonite ... its not eough to hold the box up well.
for 100 bucks, eh.. i mean its cheap.. but i hated mine.. and i ran a flat 13 jl w imprint sound processing.
Old 04-01-2014, 10:10 AM
92K1500
92K1500's Avatar
Link wont load but I agree with bmc. It's a terrible placement for a sub. Bass soundwaves are way too long to have the sub that close to the front of the car. Plus having them in the back of the car makes the hatch act as a horn.
Mine is in the back in a sealed box facing up and I wouldn't change it for any other placement or orientation.
Single sealed 12" on 750w (clamped) and I can flex the windshield, wipers, mirrors, visors and steering wheel. I'm sure the hatch lid goes crazy too but I can't see it while I'm in the driver seat.
Old 04-01-2014, 02:18 PM
ohmicide
ohmicide's Avatar
really? that bad? I mean the Bose sound system isn't THAT bad, I don't need earth shattering bass but the stock system isn't quite cutting it for me, I make my living as a music producer and I need a good reference to check my mixes
my main beef with the Bose system, other than the stupid audiopilot, is that the sub doesn't extend very much, probably cuts off at around 40 to 50hz which is pretty bad, I need the sub to go down to at least 25hz
if it wasn't for that then I would probably just hold off until I can get a second hand stealthbox for a good price
Originally Posted by 92K1500
Link wont load
here's the new link
http://srqcustoms.3dcartstores.com/N...-10_p_160.html
Old 04-01-2014, 02:24 PM
bmccann101
bmccann101's Avatar
Reference is the farthest thing from that box set up.. ear shattering or not..its not a question of volume..rather its one of response ..
This is NOT the box for you..
Stealthbox is good but very spendy..
Seriously.. the z enclosure single woofer box is a cheap way to great great sound.
Old 04-01-2014, 02:33 PM
92K1500
92K1500's Avatar
The box itself appears to be decent quality but the mounting design is insufficient. Even the glovebox uses support brackets in the back. I see that thing breaking after a few good bumps or rough roads.
And the stock BOSE system is garbage. It didn't even last a year and I stripped it all out and started from scratch.
My sub is custom made. The Fs when it was new was 18hz and in my sealed box it peaked in the car at 38hz. It can go as low as you want it to.
Old 04-01-2014, 08:26 PM
ohmicide
ohmicide's Avatar
bummer, would really like to keep the stock look as much as possible, I also feel like it's an overkill and waste of space to have such a big box for a single 10' sub
I'm definitely not a huge fan of having the sub right behind the driver seat though, my number one choice would probably be a corner box, but the only decent looking ones I've found are way too expensive
that was one of my main concerns actually
Old 04-02-2014, 05:12 AM
92K1500
92K1500's Avatar
You have to have enough airspace for the sub. Some require more, some require less.
I have my single 12" in 1.3 cubes after displacements.
Old 04-02-2014, 05:13 PM
ohmicide
ohmicide's Avatar
I think I might have to temporarily install the a new sub behind the driver seat until I can get a nice corner box made like this one
Originally Posted by *ICE*
I got this fiberglass box make for $200
I was starting to be ok with the idea of throwing a sub box between the seats and the hatch bar but then today I realize my dog fits in that spot pretty comfortably
350Z_Al
10-29-2020 07:44 PM
11-01-2015 05:25 PM
Quick Reply: SRQ Custom Autosound Stock Subwoofer enclosure?
