350Z Dash Kit Problem
Old Jan 9, 2011 | 05:26 PM
Adam U's Avatar
Adam U
Default 350Z Dash Kit Problem
Hi,
I have recently purchased a 2007 350z and I am changing the stock Bose head unit. I have purchased a double din unit and a dash kit and I am having issues fitting it, the dash kit doesn't fit my HU.
I understood that the standard double din dimensions are 180mm x 100mm (7" x 4"), this is also the size of HU. The dash kit I purchased was advertised as a double din kit but measures 176mm x 98mm and consequently does not fit. (See below)
http://cgi.ebay.com/ebaymotors/ws/eB...TM:MOTORS:1123
Am I missing something here? Can anyone recommend a dash kit the will fit the correct standard double din dimensions (180mm x 100mm)?
Thanks for the help
Old Jan 9, 2011 | 06:04 PM
demonz06's Avatar
demonz06
This is the one i got for my Pioneer AVIC-X90BT DD, fits perfect
http://cgi.ebay.com/ebaymotors/2006-...#ht_3132wt_873
Old Jan 9, 2011 | 07:20 PM
350ZTheStandard's Avatar
350ZTheStandard
This is what I have & it fits like a charm, good ruck feLLa.
http://www.techronics.com/caraudio_1...html?aff=72182
Old Jan 10, 2011 | 08:13 PM
orgasm_donor's Avatar
orgasm_donor
The big question is......
What deck are you running? If it is an Ebay Chinese branded el cheapo double din deck then that is the problem right there. I have found that most of these cheapie knock-offs are oversized in both width and height. In this case I usually have to trim down the kit a couple of mm's to make the deck fit in which case I charge accordingly for that.
But I usually send the customer away or sell them a proper double din deck. Now, if you have an Alpine, Pioneer, Kenwood, Clarion or whatever name brand deck then the kit is defective or just needs to be trimmed down.
Old Jan 10, 2011 | 11:52 PM
Adam U's Avatar
Adam U
Thanks for the links guys.
Yes its an ebay unit, however I have measured the face of it and its 180mm x 100mm which from what I found online is the standard double din dimensions. It was the dash kit that measured up too small although advertise as double din dash kit.
I will try this kit (below) and it should fit, if for any reason it doesn't il have to trim it down.
http://cgi.ebay.com/ebaymotors/ws/eB...#ht_3872wt_873
With this wiring harness will I still need the PAC ROEM-NIS2 or will this solve the problem?
Old Jan 11, 2011 | 01:10 PM
350ZTheStandard
OP you can get all this for much less with my link through schosche, one of the largest manufacturers of OEM stereo kits.
Old Jan 17, 2011 | 10:58 PM
Nismo Ninja's Avatar
Nismo Ninja
I have heard nothing bad about the Metra Kits:
http://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
I believe they have one for the 07 and up, actually cheaper, as well. I've just ordered mine and can't wait to install my Kenwood HU.
Old Jan 17, 2011 | 11:52 PM
Nismo Ninja
Hey Orgasm_Donor, I just purchased a Kenwood DNX HU and it has the KCA-BT300 bluetooth mic, and the gps antenna. I was just wondering on how you, the proffesional, would install it on a Z? Would you snake it through the speedometer and up the A-piller? This is my first time installing a HU and optimal mic placement is throwing me off. Any advice you can give me would be awesome!
Old Jan 19, 2011 | 03:48 AM
Doc_Z's Avatar
Doc_Z
Sorry if this is off topic, but I would like to know:
a) where to buy the metra (or another preferred) dash kit?
b) Is there really a diff between the year models? I have an 04 model 350z with Bose.
I have a Double Din JVC in there now that I wanna sell and get a single din Alpine. (Good double din units are rare or expensive)
Old Jan 19, 2011 | 06:57 PM
Nismo Ninja
I have an 04' as well and this is probably the cheapest I could find:
http://www.sonicelectronix.com/item_...ROEM-NIS2.html
And yes the years matter because they started using a different type of center/cubby/console after 05' I believe.
Old Jan 19, 2011 | 07:39 PM
Nismo Ninja
Some extra help along the way and some cool ideas while you're in there!
https://my350z.com/forum/audio-video...monitor-5.html
Old Jan 19, 2011 | 09:11 PM
orgasm_donor
Best to run it under the steering column and zap strap it up so it doesn't get in the way of anything.
Old Jan 19, 2011 | 09:22 PM
NismoZZ's Avatar
NismoZZ
Originally Posted by Adam U
Hi,
Thanks for the help
The problem is you purchased half a dash kit if you look at your dash kit you bought all you got is a frame and the bottom insert for a single din stereo. If you look at the link below your post this is the correct dash kit see how it has arms so you can bolt the kit to the center dash. With your kit anyone could come in and basicly just pull your stereo out put there's nothing to bolt it in tight or even bolt it in at all.
the link below is also from ebay and this will work with your setup
http://cgi.ebay.com/2003-2004-2005-N...=item242f2b8c1
Chris350z03
Oct 8, 2023 07:19 PM
Juztin
Nov 22, 2015 07:03 AM
Vigman
Nov 17, 2015 04:34 AM
EnjukuRacing
Sep 11, 2015 08:30 AM
