focal polyglass 165 v2?
Old Dec 8, 2003 | 11:55 AM
liptonme's Avatar
liptonme
Question focal polyglass 165 v2?
Just wondering if anyone had any opinions on this component system? Thinking about putting them in for the front speakers. Going to power it with a JL 300/4. I was also looking for a website to see the specs but didn't see one in English???
Old Dec 8, 2003 | 12:16 PM
zand02max's Avatar
zand02max
Awesome set of componets. I am going with those to rplace my Kickers, or I will go with the more expensive Utopias.
Go here:
http://www.onlinecarstereo.com/CarAu...roductID=12970
and here for all the other focal speakers.
GL!!!!!!
http://www.onlinecarstereo.com/CarAu...?CategoryID=16
Old Dec 8, 2003 | 12:22 PM
zand02max's Avatar
zand02max
General Specifications
Sensitivity: 93 dB
Sensitivity: The rating of a loudspeaker that indicates the level of a sound intensity that the speaker produces (in dB) at a distance of one meter when it receives one watt of input power. The Efficiency or Sensitivity rating indicates how effectively a speaker converts electrical power from the amplifier into sound pressure. This is frequently related to larger magnet sizes, larger voice coil diameters, and more compliant suspensions. Optimized enclosures are essential in achieving maximum sensitivity, overall. The higher the Decibel number, the more efficient the speaker and the louder it will play with the same input power. While usually more expensive, an efficient speaker helps maximize the potential of the available power.
RMS Power Range : 75 Watts
RMS: Root Mean Square is a formula that provides a reasonably accurate means of measuring and comparing continuous AC power. The use of this measure is preferred when matching system components, like amplifiers and receivers.
Peak Power Handling: 150 Watts
Peak Power Handling: Peak power handling refers to the amount of power a speaker is estimated to handle during a brief high-intensity musical burst. Since this can vary with both frequency and amplitude, it is a much less accurate way to judge speaker durability and performance than RMS.
Frequency response: 60-20000 Hz
Frequency Response: The range of frequencies that a speaker will reproduce (lowest frequency to the highest). While the optimal normal is 20 - 20,000 Hz (Hertz), the range of human hearing for individuals is often much more restricted. A good full-range speaker system however, will reproduce as much of this range as possible in order to cover all variations. Individual Drivers are limited to reproducing only that part of the spectrum for which they were made, so their response will be limited, but still a necessary point to consider when designing a complete sound system.
Diameter: 6 Inch
Features
Polyglass membrane
Inverted dome tweeter TN 47 Tioxid 5
Filter 12/12 dB
Woofer: 165mm.
Voice Coil: 25mm.
Motor: 84mm.
Tweeter: Tioxyd 5 TN 47.
Filter: 2-way 12dB/octave (adjustable tweeter and midrange level).
Max. power: 150W.
Nom. power: 75W.
Sensitivity: (2,83 V/1m): 93dB.
Frequency response: 60Hz-20KHz.
Grilles supplied.
Old Dec 8, 2003 | 12:32 PM
liptonme's Avatar
liptonme
nice write up thanks. however.... i think it's 6.5 inches, not 6 inches. Also, the price is a bit cheaper on discountjungle.com but not sure about the website reliability.
Old Dec 8, 2003 | 01:11 PM
zand02max's Avatar
zand02max
That link is terrible, I have never seen so many pop-ups, grrr, hate websites like that. I refuse to buy from folks who have pop-up ads and when you X them out another appears.
Old Dec 9, 2003 | 02:13 AM
jreiter's Avatar
jreiter
Then stop using IE as your web browser! Seriously though, I'm sort of a Mozilla evangelist; I can't recommend it enough. It will allow you to turn that crap off, and you'll never be bugged by unwanted pop-ups again.
Old Dec 11, 2003 | 03:04 PM
Horizon1's Avatar
Horizon1
indoaudio@aol.com is a dealer on ebay that sold me a set of these. Excellent speakers and good bang for the buck. Not bright at all, very good sounding. I have it powered by the same 300/4
Old Dec 12, 2003 | 11:34 AM
liptonme's Avatar
liptonme
Horizon.......
What was the price please? It's 250 with shipping online...
ss350
Apr 30, 2004 10:48 AM
liptonme
Feb 3, 2004 01:28 PM
liptonme
Jan 15, 2004 02:32 PM
liptonme
Dec 18, 2003 08:23 AM
Vincey2kr1
Oct 23, 2002 04:42 AM
