HeadUnit Installed Problems
Old Jan 28, 2012 | 04:01 PM
thall's Avatar
thall
Default HeadUnit Installed Problems
I have a 2003 touring edition and had a head unit install after the install my pod gauges or dash cluster doesn't work. The car will run fine during the day but at night the battery dies. I've check all the fuses under the dash and inside the car and they are all good. Any help will be greatly appreciated!!!!!
Old Jan 28, 2012 | 04:16 PM
sportbiketed's Avatar
sportbiketed
Take everything apart and see if there are any damaged wires that may be grounding out.
Old Jan 28, 2012 | 04:18 PM
thall's Avatar
thall
I've had everything out twice and everything looks good.
Old Jan 28, 2012 | 04:21 PM
sportbiketed
Check again. That issue shouldn't be caused by a simple deck install.
Old Jan 28, 2012 | 04:29 PM
thall's Avatar
thall
Okay. I will try tomorrow.
Old Jan 28, 2012 | 05:36 PM
R350Zz33's Avatar
R350Zz33
u have an amp to or just a new deck?
Old Jan 28, 2012 | 07:27 PM
beezee's Avatar
beezee
If you installed an amp, check to make sure your remote wire is connected. Also check and make sure your cluster gauge connector is plugged in all the way. Make sure you hear a click.
Old Jan 29, 2012 | 07:02 AM
thall's Avatar
thall
I've checked again this morning. The remote wire is connected and the gauge connector is plugged all the way in.
Old Jan 29, 2012 | 07:08 AM
R350Zz33's Avatar
R350Zz33
if you have an amp make sure the power wire isant touching the remote area
Old Jan 29, 2012 | 12:32 PM
thall's Avatar
thall
Do these cars have fusible links if so where are they located?
Old Jan 29, 2012 | 04:20 PM
sportbiketed
No.
Uriyo_
Sep 8, 2021 08:46 AM
