Installing a double din stereo in the Nav spot
Old Feb 5, 2013 | 07:10 AM
DenverRand's Avatar
DenverRand
Default Installing a double din stereo in the Nav spot
New 350z owner here and wanted to see what issues people have come across installing a double din stereo in the compartment where the nav system usually is.
My Z has the Bose CD/tape/radio combo installed in the lower part of the dash and doesn't have a nav system.
I want to install the Pioneer AppRadio 2 (a double din system) in the place the nav system normally would be and take out the factory radio and put some sort of filler compartment in its place.
I talked to a stereo store yesterday and they said they'd have to custom make a mount if I wanted to install something in the place where the nav unit usually is.
Anyone have any advice/suggestions?
Thanks!
Attached Thumbnails Installing a double din stereo in the Nav spot-stereo.jpg
Old Feb 5, 2013 | 07:14 AM
Spike100's Avatar
Spike100
You cannot install a double-din device in the stock navigation screen slot. Even if you create a custom mount, the upper forward cubby does not have adequate depth. It would protrude too far and look awful.
The upper forward cubby works well for an LCD screen --Spike
Old Feb 5, 2013 | 07:21 AM
DenverRand's Avatar
DenverRand
Spike - thanks, I appreciate the response.
Old Feb 5, 2013 | 07:28 AM
donj's Avatar
donj
Dam I was thinking of doing the same
Old Feb 5, 2013 | 08:35 AM
beezee's Avatar
beezee
Mostly members that ask this question want to keep the stock radio look but you are actually going to take the radio out. so why not install the double din in the stock location and leave the already "filler compartment" up there?
a radio install guy will do whatever you tell them to without regards to how it is going to end up looking. they work for money
I want to install the Pioneer AppRadio 2 (a double din system) in the place the nav system normally would be and take out the factory radio and put some sort of filler compartment in its place.I talked to a stereo store yesterday and they said they'd have to custom make a mount if I wanted to install something in the place where the nav unit usually is.
Thanks!
Old Feb 5, 2013 | 09:15 AM
morphiusrt's Avatar
morphiusrt
Just install it in the stock location. You will definitely have to cut a lot to get it to fit up there. It is slightly shallower then most double dins due to the fact it doesn't have a dvd/cd slot.
Here's mine installed in the stock location App-radio
Old Feb 5, 2013 | 10:42 AM
DenverRand's Avatar
DenverRand
Well, the main reason I wanted to install the Pioneer AppRadio 2 in the compartment where the stock navigation usually is placed is because I wanted to be able to close the door over the stereo to hide it since the faceplate/screen on the AppRadio 2 isn’t detachable (at least not that I’m aware of). The other reason is that it would put it at a better eye level in that upper position rather than having it down in the stock position.
I’m set on the AppRadio 2 as my choice to install in the car. I’m going to meet with an audio shop here in Denver that does a lot of custom work and see what they think they might be able to do to put it in the upper compartment with the door and still have it look good (if it can be done).
Old Feb 5, 2013 | 10:45 AM
Deteria's Avatar
Deteria
You can install a screen where that cubby is? But if you were upgrading stereo, why would you want to keep the stock radio?
Old Feb 5, 2013 | 10:57 AM
beezee's Avatar
beezee
good luck. let us know how it turns out and how much it costs you.
Old Feb 5, 2013 | 11:04 AM
JohnG202's Avatar
JohnG202
I installed the App radio 2 a few months ago. Looks like a stock item so I wouldn't worry about it getting stolen. If you leave the door on to cover up the radio, won't it get annoying having the door above the "nav"?
I use the cubby for my ipod/droid hookups. I need to put a mount for my ipod and droid in this winter so come spring it'll be all set to go.
Old Feb 5, 2013 | 11:37 AM
DenverRand's Avatar
DenverRand
"Deteria" - I don't want to keep the stock radio. I'm getting rid of it and installing a Pioneer AppRadio 2, but don't want to install it in the place the stock radio is currently placed.
"JohnG202" - yeah, I see what you mean. I guess this whole exercise is kind of pointless now that I really think about it because of the way the door is when it's open. I guess I'd still like to try to get the new AppRadio 2 installed in the place where the "cubby" is, but will forget about having a door to cover it. Wasn't thinking straight.
ablaine
Nov 29, 2016 10:13 AM
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
