07 Roadster, Replace Bose, now no ac blower
Old Mar 15, 2014 | 03:06 PM
KJACK357's Avatar
KJACK357
Default 07 Roadster, Replace Bose, now no ac blower **Solved**
Sorry guys, i did do a search for this but nothing turned up.
2007 GTR With Bose and nav
Installed Pioneer Double Din, New speakers and amp..bypassed all Blows components.
Now after everything reassembled, i have no ac blower. All the lights on the finisher will light up, i hear the ac compressor engage when ac is turned on.
The fan or blower will not work.
I have googled but found no concrete answers.
Ay ideas ?
***Replaced Blower Relay behinD fuse box on drivers side kick panel.
Fan blows strong! ***
Thanks
Old Mar 15, 2014 | 05:09 PM
flynzed's Avatar
flynzed
Ay ideas ?
Thanks
I had a simular issue when I swapped out the head unit in my Frontier, check your connectors, I had one not completly in so the clamp/snap was only catching one side.
Old Mar 15, 2014 | 05:24 PM
Spike100's Avatar
Spike100
Be certain you re-connected the ribbon-wires correctly and that it is fully seated.
See these threads:
https://my350z.com/forum/audio-and-v...t-install.html
https://my350z.com/forum/audio-and-v...-problems.html
Old Mar 16, 2014 | 05:46 AM
KJACK357's Avatar
KJACK357
Thank you guys for the response,
Unfortunately, i had tried those trouble shooting tips with no success.
The funny thing is, it was working but the "Service Engine Soon" light was on so I disconnected the battery ground for about 10 minutes to reset the light. The light did go off
but the AC blower problem started.
At my wits end!
Old Mar 16, 2014 | 06:48 AM
beezee's Avatar
beezee
Access to the blower is not that hard.
I will put a tester on the blower wire to see if it is getting power. Co incidents happen and it could have gone bad.
Old Mar 16, 2014 | 07:25 AM
KJACK357's Avatar
KJACK357
Thanks, I'll try that and report back.
Old Mar 16, 2014 | 08:51 AM
KJACK357's Avatar
KJACK357
blower is receiving power.
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
