Amplifier cable
Old Sep 9, 2021 | 09:43 AM
JCat's Avatar
JCat
Default Amplifier cable
The box store amplifier cable (4 gauge) appears to be composed of very VERY fine strands of copper wire.
I have read that when "finer" wires are used in cable construction, that it actually reduces the cables ability to perform. I have also discovered that these fine cables are more prone to corrosion and failure at their junction points, clamped, soldered, or crimped. (in use since 2004)
I am about to upgrade my system, and I am inclined to use "vehicle grade" battery/starter/ground wire. (because the wire strands are much thicker)
Before I spend my money . . . Comments?
Old Sep 9, 2021 | 01:18 PM
travlee's Avatar
travlee
Master
I read that power travels around the strands, and that is why more is better for audio applications. Not sure how true or accurate that is
Old Sep 10, 2021 | 07:48 AM
iideadeyeii's Avatar
iideadeyeii
I've used thhn wire before. I don't think it matters as long as it's rated for the power
Cavemanz33
Dec 16, 2017 07:55 AM
Interlagos Fire
Oct 13, 2006 08:39 AM
350ztoronto
Jun 13, 2006 08:50 AM
rummya87
Jan 20, 2005 04:01 PM
weslutes
Nitrous Oxide
Nov 6, 2004 07:25 PM
