need help capacitor question
Old Jul 8, 2004 | 05:08 AM
andyisphat2004's Avatar
andyisphat2004
Default need help capacitor question
I ran a search but i couldnt find the answer. Here are the amps I am running:
jl 450 x4
jl 1000x1
jl 500x1 (installing this week)
I am currently using an optima battery and no capacitors. My question is this, if i did use a capacitor should i hook it in before teh power distribution block. (there is 1 cable coming from teh battery, it goes into a block and then splits into 3 cables coming out). Or should I use 1 capacitor before the 1000x1 and 1 capacitor before teh 500x1.
thanks
andy
Old Jul 8, 2004 | 04:54 PM
andyisphat2004
anyone?
Old Jul 8, 2004 | 05:20 PM
MonkeyBoy's Avatar
MonkeyBoy
You can do the caps like you suggest, or have a two farad cap that feeds both your 1000/1 and your 500/1. Just make sure the cap is close to your amps.
Old Jul 8, 2004 | 05:21 PM
MonkeyBoy's Avatar
MonkeyBoy
By the way, I love my JL Amps as well! I only have a 1 Farad cap in line with the 500/1. I leave the 450/4 out of the loop since the current draw will not spike with large bass hits. It is not recommended to put the cap close to the distribution block. Keep it as close to the amps as possible. I have about an eight inch 8-gauge wire running from the cap terminal to the amplifier power input.
Old Jul 8, 2004 | 06:36 PM
BoostTed's Avatar
BoostTed
what is the 500/1 going to be powering?
Old Jul 8, 2004 | 08:04 PM
bigern1970's Avatar
bigern1970
Default Re: need help capacitor question
jl 450 x4
jl 1000x1
thanks
andy
Put cap after distribution block ,,,,,,,,,I would only run the amp that is runnin the sub or subs.....since they drain more power , I run a 1farad for my 500/1 wich runs a 10 w7
Old Jul 9, 2004 | 05:51 AM
andyisphat2004
500x1 is going ot be running a 10w7
100x1 is going to be running 2 10w7.
i know it is completely overkill, but i either wanted to take it down to only 2 subs or have 3 running happily (with them only getting 333watts each like they do now, sometimes they "pop" b/c the amps cant push out enough power). I decided to stick with 3 subs b/c i like the look alot better and have already invested $$$ so buying one more amp really doesnt bother me that much.
Old Jul 10, 2004 | 10:00 AM
done12many2's Avatar
done12many2
Overkill is an understatement!!! I have two 10W7-3s on a JL Audio 1000/1 and it is nothing short of painful at high volumes. Not to mention that the car is literally shaking itself loose when played like that. When I hit a solid 35-40 Hz note, my back window looks like its about to come out of the hatch. Of course my 10W7-3s are in vented enclosures tunes at the JL spec 32 Hz.
Old Jul 12, 2004 | 11:54 AM
brandy's Avatar
brandy
You should use the cap as a distribution block and make the power leads to the sub amps as short as possible. If you have a canister type cap you can stack the power leads on top of each other, pretty sure you can fit 3 terminals on one even with the battery terminal. The Alumapro ones are even easier since they screw down like most amps do but you have to rig up a relay.
Old Jul 12, 2004 | 05:27 PM
stu46's Avatar
stu46
Just stick another battery behind the driver seat. BTW, post some pics. I'd like to see where you get the room for 3 w7s.
Old Jul 13, 2004 | 09:39 PM
andyisphat2004
stu,
havent hooked up the 500w amp yet, but here is where they all are. I do have an extra battery but didnt really want to use it.
andy
Old Jul 13, 2004 | 10:12 PM
MonkeyBoy's Avatar
MonkeyBoy
That makes my ears hurt just looking at it.
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
