VDC Button Wire Schismatic
Old Jan 3, 2018 | 02:51 PM
Franknbeans's Avatar
Franknbeans
Question VDC Button Wire Schismatic
Hey guys,
Does anyone have a wire diagram of what the 4 pins do in the VDC switch?
Have an idea and would like to use a stock OEM looking switch.
Old Jan 4, 2018 | 05:15 AM
karlt's Avatar
karlt
Look in the brc.pdf section of the Service Manual.
Old Jan 4, 2018 | 05:29 AM
Franknbeans
Is the manual online? I don't have one.
Old Jan 4, 2018 | 05:36 AM
dkmura's Avatar
dkmura
General & DIY Moderator
Nissan Infiniti Club Owners (NICO) offer FSMs for the Z33 here:
http://www.nicoclub.com/archives/nis...e-manuals.html
Old Jan 4, 2018 | 11:14 AM
Franknbeans
Looks like it'll work for what I am wanting to do.
My idea to fully disable the VDC by lifting the ground wire on the yaw control unit and use the "extra" VDC switch for this. Mount the switch where the extra blank is by the window switches.
Old Jan 4, 2018 | 06:05 PM
KRyn's Avatar
KRyn
You should detail how you do this. I have already acquired a spare VDC switch but will not get around to attempting this for a few months still as my car is in storage. I don’t like doing anything that involves wiring so a DIY guide would be nice to follow. I found a few DIYs using basic toggle switches on the forum.
Old Jan 4, 2018 | 06:17 PM
Franknbeans
For sure. But it'll be a bit for me to. I live in North/West PA. I won't have access to the Z until the snow starts melting off.
I'm not 100% sure why it hasn't been done this way, so I am not sure if it'll work yet. I guess I'll find out for everyone else. LOL
Old Jan 5, 2018 | 02:18 AM
karlt's Avatar
karlt
The VDC switch is momentary. Press it and it's on, release it and it's off. I don't think that will work for the function you intend.
Old Jan 5, 2018 | 04:07 PM
Franknbeans
Yeah, I thought about that too. I need to check, but I assume the YAW sensor will not reset when I pull the ground wire until the car is shut off and turned back on.
Old Jan 5, 2018 | 10:14 PM
KRyn's Avatar
KRyn
This is correct. All you need to do is momentarily interrupt the ground/power and it will fault the yaw sensor. Completely disabling all traction / VDC systems, which will only reset when you power cycle the vehicle.
Old Jan 6, 2018 | 01:38 AM
karlt's Avatar
karlt
Not to be too picky, but is that based on personal experience or just something you read?
Old Jan 6, 2018 | 02:55 AM
KRyn's Avatar
KRyn
It is well documented on this forum.
See HERE and HERE.
Old Jan 6, 2018 | 08:20 AM
karlt's Avatar
karlt
Thanks. That's good information.
Old Jan 25, 2018 | 04:29 PM
Franknbeans
Well, I couldn't find a VDC button with the plug and wires but I did find a heated seat button with the plug. So, I'll be using this switch instead.
When it warms up a bit I'll put together my DIY for this mod. I really think just pulling the ground on the yaw control box will be the easiest way to do it.
Old Feb 17, 2018 | 05:34 PM
Franknbeans
FYI, for anyone that reads this and doesn't stubble on my build thread. Pulling the ground wire form the YAW sensor works absolutely fine and you don't have to worry about blowing fuses if you do it this way.
Old Feb 27, 2018 | 05:38 PM
Surfer90291's Avatar
Surfer90291
Anyone figured out how to disable TCS for 08 350z? We don't have a yaw sensor
Old Feb 28, 2018 | 02:30 AM
karlt's Avatar
karlt
If your car has TCS but not VSC, simply push the TCS OFF switch.
tokdemir
Aug 16, 2013 08:51 AM
dhwang80
Apr 11, 2008 01:33 PM
rummya87
Mar 10, 2003 08:52 PM
