Track pads database?
Old May 10, 2010 | 06:46 PM
  #161
AznSky's Avatar
AznSky
I'll be running carbotech's XP10 Front XP8 Rear this Thursday on my 05 standard brakes, I'll let you know how it goes (although forecast is rain so don't know how much I'll be heating them up)
Old May 11, 2010 | 03:22 AM
  #162
DavesZ#3's Avatar
DavesZ#3
Originally Posted by sektor 11
While agree with that the problem is: many aren't offered for the base. I'm looking for some help with finding a good set of pads for the track that are offered for the base z.
The 350Z only has two brake setups, Brembo and non-Brembo. The non-Brembo brakes are the same on all models, i.e. base = enthusiast = touring.
Old May 11, 2010 | 03:36 AM
  #163
AshMan's Avatar
AshMan
Club Moderator
the Hot Spot
I changed out my fronts almost a year ago with EBC "Red stuff" brake pads & love them. They've held up well through a track day & multiple country road trips. They're made out of a compound that is kevlar/ceramic based. I highly recommend googling them. They have very low brake dust.
Old May 11, 2010 | 04:28 AM
  #164
roger22's Avatar
roger22
Forget EBC, go with a good real track pad like Raybestos or Hawk pads..
Old May 11, 2010 | 05:13 AM
  #165
sektor 11's Avatar
sektor 11
[QUOTE=terrasmak;8372436]Your going to need 2 new stub axles, your base ones are the tapered ones like mine were. In the next couple days i'll post more info , mine are in process of being machined to fit. QUOTE]
I was told for the base the OS giken is a bolt in on the 2006 from Z1. You're saying otherwise?
AznSky- where did you pick up your carbotechs from?
Old May 11, 2010 | 06:11 AM
  #166
thekinn's Avatar
thekinn
I used EBC Yellows (I think these were supposed to be better than Red) - They barely lasted one track day - and it was a small 1.5 mile - top speeds about 100. Using oem non-brembo 06 calipers.
I'd vote for the Carbotech's too. I used Xp8's front/rear for two track days and had some meat left.
Oakos has them, or can get them. oakos.com - they are a vendor here.
btw - I have some 06 calipers that haven't hit the marketplace yet...
Old May 11, 2010 | 06:26 AM
  #167
mhoward1's Avatar
mhoward1
For track only pads I can personally recommend the Carbotechs as well.
XP12's up front and XP10's in the rear. You can Call Carbotech directly and they will ship the brakes to your house.
Old May 11, 2010 | 06:30 AM
  #168
plumpzz's Avatar
plumpzz
I have wilwood BP20 material in the front and XP10 material in the back and I can't complain.l I may go with a more aggressive front material since I was getting some vibrations at the end of the session.
Old May 11, 2010 | 07:22 AM
  #169
MrLizard's Avatar
MrLizard
I use Ferodo DS3000, was using the 2500's which were good but the 3000's are better.
http://www.raceshopper.com/ferodo_brake_pads.shtml
not a bad bite from cold but once there is some heat in them they start reacting very well, when the car was fast road use i tried EBC products, didnt think they were too bad but not on the same level.
Old May 11, 2010 | 08:05 AM
  #170
mw9's Avatar
mw9
Same for me and street and autox I use the AX6 pads.
Old May 11, 2010 | 08:09 AM
  #171
sektor 11's Avatar
sektor 11
Great! Thanks for all of the info everyone!
Old May 11, 2010 | 08:58 AM
  #172
AznSky's Avatar
AznSky
yeah you can order directly from carbotech ctbrakes.com
HOWEVER! As a warning, carbotech screwed up my and my friends order. Sent us both the wrong pads (we ordered separately). Luckly I was able to get a set of correct carbotech parts or else I would have been pissed. Plus they're giving me a full refund so they're customer service is good, but just make sure they send you the right parts lol.
Plus you can get NASA or SCCA discount through them. But they still are pricey pads. I only plan to run these through and prolly get a bbk next since the pads themselves are expensive.
As for other vendors, Oakos or Forged both sell carbotech's. A friend with a 370 actually said Forged was cheaper than directly from ct.
Old May 11, 2010 | 10:01 AM
  #173
sektor 11's Avatar
sektor 11
Afriend of mine also ordered direct from carbotech and he also got the wrong pads for his type r. interesting.
Old May 11, 2010 | 11:27 AM
  #174
mhoward1's Avatar
mhoward1
Carbotech makes a great compound, but in truth they just aren't the same since MaddMatt left.
Old May 11, 2010 | 12:01 PM
  #175
terrasmak's Avatar
Thats correct , good read https://my350z.com/forum/engine-and-...-pull-out.html and they told me it was a direct bolt in too.
Old May 11, 2010 | 01:16 PM
  #176
betamotorsports's Avatar
betamotorsports
Porterfield Brakes will custom cut brake pads for the base 350Z brakes from any pad material they sell. I've run Hawk DTC70 pads on my base 350Z brakes.
Old May 12, 2010 | 08:12 AM
  #177
scotts300's Avatar
scotts300
I have Porterfield cut some Raybestos ST41 and ST43 calipers special for my non-Brembo (rears). They actually last a few events: sales@porterfield-brakes.com
I am in the midst of upgrading to Brembo rears, so have a bunch of non-Brembo rear pads (street and track) if you'd like to try some for cheap. You also need to consider the rear rotors a consumable, and just bite the bullet. At least they're cheap.
Old May 12, 2010 | 08:54 AM
  #178
Hokie350Z's Avatar
Hokie350Z
I've heard that the Girodisc Magic pads and the Racing Brake ET500 are both good on the non-brembo Z
Old May 13, 2010 | 09:47 AM
  #179
SoarVigor's Avatar
SoarVigor
Personally, Hawk ceramics will do.
Old May 13, 2010 | 10:33 AM
  #180
03threefiftyz's Avatar
03threefiftyz
Hawk Ceramics have no business on a track
Or what this f@ggot said.
Unnecessary
