Alignment—Do individual readings matter or just totals?
Not getting any feedback in the general suspension thread...can you track guys read my alignment like my tarot cards and tell me what lies in my future? LOL. Thanks:
https://my350z.com/forum/brakes-and-suspension/272130-alignment-do-individual-readings-matter-or-just-totals.html
The car will probably drive straight, but the rear toe and camber is out big time. If you have lowering springs this will cause the camber & toe to be out in the rear. Rec some camber and toe arms to correct the issue. If you don't have springs has the car been wrecked? Either way the arms will correct the rear problem.
With rear toe both being set to the left and rr wheel camber leaning in that much, when going over a bump the rear of the car may feel like it wants to jump left.
The front is so so, but none of this is that quality of an alignment. They should have told you that your going to have problems with tire wear and the car should not handle all that well compared to what it should be at.
So what is all on your car suspension wise?
Mike
edit: after looking at it again they did not adjust the rear at all!
Mike
I had a similar problem:
https://my350z.com/forum/showthread....light=hotchkis
I actually took my car back to the dealership to re-do but I had a feeling they just tweaked the numbers a little bit (not sure but it's a possiblity) since the second time I took it in, the numbers changed drastically. My service advisor at WCN told me that the front camber on stock Z's are just not tune-able. There's no room for adjustment, yet on my second print out the numbers changed drastically.
To me, your camber seemed okay before you took it in, but your left rear is pretty off. I think spec is (0.03-1.8) on all four corners. Maybe you could take it back or get a second opinion at another place. Some places can "bend" your suspension pieces to get it back to spec but it's not recommended.
Mike
Mike
No wrecks (owned since new) and I am lowered on Hotchkis springs which most have been able to get back into spec.
Anyone know a good place to get a performance alignment in the Tampa Bay area?
Originally Posted by 350Zenophile
That's right! They didn't touch the rear at all...Do you know if the rear camber can be adjusted independently from toe?
When you adjust camber it changes toe, vise versa on the toe but not such an effect as the other.
Now the rear of the Z the toe and camber are two different lower arms. Since you have ansewered yes to the suspension question, I take it is about a 1 inch drop from looking at the alignment. If they are adjustable coil raise up the rear an 1/2 inch. This will allow the rear toe and camber to come back into specs.
Check the ride height off the frame at the front and rear. The rear can be slightly higher with no ill side effects.
Later on when your ready pick up some camber and toe arms for the rear, they allow for more adjustment.
Here is a link for what I am talking about. Serveral people make them, just use your best judgement on what you need is.
http://www.stillen.com/product_images/308370.jpg
Oh and no I would not take it back to the same dealer.
I don't have coilovers, just springs. Hotchkis springs are a mild drop at 15mm in the front and 19mm in the rear and from my online research everyone seems to be able to get them back to within factory specs with the factory control arms.
That's all I'm really looking to do, get an alignment within factory spec to save my tires and if possible with a slant toward performance. Thanks for your help.
Just remember everyone’s car is slightly different when it come so the whole assembly of suspension, this is why the factory has adjustment. What the factory does make adjustments for is when you change the geometry of the suspension (ie lowering the car). Thus this is why there are aftermarket companies filling in a void where the manufacturer left off.
Believe me you are not the first to have to buy adjustment arms when other don’t.
Mike
With the rear at nearly 3/4" of an inch drop you’re in the gray area of being able to achieve factory spec. Some z's will, some z's will not. I would take it to another alignment shop, a race shop, if their is one near you. But with what I am reading you will have to much camber left and right rear in order to have the toe happy. It's a compromise, but the rear tires on the Z never last very long anyways.
Mike
Mike
so a nissan dealership is totally incapable of doing an alignment for a dropped car?
Mike
Mike
The dealer he went to did a poor job and did not even touch the rear of his car according to the print out. So why go back to argue with some one who does not understand what they are suppose to do in the first place.
Their are plenty of good dealers with well trained tech's that are capable to do a proper alignment, for that fact a lot of the local tire stores to a great job as well. But every real race shop (not a wannabe parts reseller) knows how to do it right the first time.
Regardless his springs are the problem and it's compounded by a poor technician and lack of knowledge on his part.
Does Hotchkis not do alignments, it is their product and they did install it right?
Sorry I was the bearer of the bad news,
Mike
Mike
Mike
Tochigi_236
Sep 27, 2015 03:40 PM
