U haul hitch for the Z?
Old Apr 9, 2008 | 03:48 PM
  #61
SSP-350z's Avatar
SSP-350z
Does anyone have pictures of this installed on the car.... I would like it so its hardly visible at all.... Maybe even not visible when looking at the car if possible.
Old Apr 9, 2008 | 04:10 PM
  #62
urban350z's Avatar
urban350z
I posted pics from the back earlier but here are a few from the back..
Its actually less noticeable with the new twin exhaust..
Old Apr 9, 2008 | 04:15 PM
  #63
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
so thats the one from summit? If so i think ill end up purchasing that one. I dont feel like fabbing up my own.
Old Apr 9, 2008 | 04:30 PM
  #64
urban350z's Avatar
urban350z
Yup thats the summit one... Just call them up and give them the part # bc they won't find it based on the car..
Oh yeah by the way... Jared, I had a good time out at nationals last month.. will be looking forward to it next year.. hopefully with some extra money to spend..lol..
Old Apr 10, 2008 | 04:12 PM
  #65
GWord256's Avatar
GWord256
I don't suppose anyone has tried this with a G35? I need to get one eventually for racing gear.
Old Apr 10, 2008 | 04:16 PM
  #66
Dave 90TT's Avatar
Dave 90TT
350Z 2+2
I've got the Curt hitch on my G35 coupe. Had to drill through the bumper brace to munt it, and a hole directly nehind the license plate, as well.
Pretty easy, all in all. Mostly hidden when the reciver ball is not on, either.
Old Apr 10, 2008 | 05:30 PM
  #67
kwadell's Avatar
kwadell
Default What year is your Z
What year is your 350Z using the hitches. I've got a 2003 and all of the hitches I've seen never say they work with the 2003 but I didn't know there was any significant differences? Anyone have a 2003 350Z that uses one of these hitches? If so which one?
Thanks.
Old Apr 11, 2008 | 09:06 AM
  #68
urban350z's Avatar
urban350z
Thanks.
Yes.. there is a difference in the hitches.. 03-05 has one and 06-08 has a different one.. The rear bracing is different on the two versions..
You have to drill holes in the bumper bracing regardless of what year you have. I am unsure ir trimming is needed on the earlier models. Some minimal is needed on the 06+.
Old Apr 14, 2008 | 04:19 PM
  #69
kwadell's Avatar
kwadell
Default confirmed usage on an 2003 350Z...
Thanks for the comments on the hitch compatibility. Any confirmed use of the CURT Manufacturing Hitch on a 2003 350Z. All the sites I've checked say something like the note below which excludes the 2003 model. If I search for a hitch for the 2003 350Z they all say there isn't one available. Thanks.
This is a custom fit application for the following vehicles.
Use the HitchHunter(R) to find what fits.
2004 - 2006 Infiniti G35 Coupe
2004 - 2005 Nissan 350Z Coupe
Old Apr 15, 2008 | 07:16 AM
  #70
JasonZ-YA's Avatar
JasonZ-YA
I think you guys should check out my other thread regarding this issue...
for the 03 i would just check what bumper support you do have and then install the right one...
https://my350z.com/forum/exterior-and-interior/347359-uhaul-hitch-249483-247483-a.html
- J
Old Apr 15, 2008 | 08:29 AM
  #71
urban350z's Avatar
urban350z
Yeah I dont know but i would call Curt and see what they say.. Use the link above in JasonZ-ya's post to get the numbers..
Old Apr 16, 2008 | 05:09 AM
  #72
JasonZ-YA's Avatar
JasonZ-YA
Default Check This Out!!!!
P/N 11493:
Click out the files!
- J
READ THREAD - SAME AS POST 14:
https://my350z.com/forum/showthread.php?t=347359
File Type: pdf
Old Apr 16, 2008 | 08:15 AM
  #73
urban350z's Avatar
urban350z
Yup.. thats the one for 06+
Old Apr 16, 2008 | 09:27 AM
  #74
JasonZ-YA's Avatar
JasonZ-YA
its also the one for my 04 -- actually 04.5 touring...
- J
Old Apr 16, 2008 | 06:19 PM
  #75
urban350z's Avatar
urban350z
Well these places have their numbers off a little... Well I guess the whole key here is remove the bumper and actually confirm which "Bumper Support" braket that you have..
It looks like the newer ones are flat and that the earlier models have an angled step on the rear side of the bracket...
Old Apr 17, 2008 | 04:34 AM
  #76
JasonZ-YA's Avatar
JasonZ-YA
ya thats what i was thinking...if not then its the G they are getting confused with..
- j
Old May 3, 2008 | 04:50 PM
  #77
laze1's Avatar
laze1
Update: Thnx to Jarred@Z1 head's-up to this area of weakness, I double checked my bumper mounts...looks like they have been flexing a bunch due to the trailer bounching up/down under load. So I am gonna weld up all the seams and add bracing where ever I can to the bumper to frame mounts.
So if you are pulling any kind of trailer weight, you might want to do this mod also.
Originally Posted by Jarred@Z1
the impact shocks the little boxes that support the rear bumper your bolting the hitch to. Thoes little black box looking things are actually crumple zones and are ment to compress during a accident.
Old May 3, 2008 | 05:06 PM
  #78
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
You're welcome. This is what i figured was going to happen. With the size and weight of the trailer you're towing i knew it would have been a problem. If it was a smaller trailer it may not be such a problem. I'll just be pulling 4 tires and a small tool bag not as much stuff so im not as worried about it.
Old May 4, 2008 | 05:45 AM
  #79
laze1's Avatar
laze1
Yep, I carry a lot of crap and still want to carry more....
....so I will weld all the seams in the bumper brackets and then try it again. This weakness was apparent after strengthening the bumper itself....so by adding strength there, it just moved the problem to the next weak link,,the brackets...that is the way it is whenever you mod....you often just move the one problems to another area of the car....
BTW: I hope to buy a real car trailer later this year, so this deal is kinda just a short term fix....however it has served me well for the last 3 years of tracking.
Old May 27, 2008 | 04:46 PM
  #80
jgray's Avatar
jgray
Is a "self power" wiring harness a universal trailer item? I'm interested in installing the Curt hitch, but I have no idea where to purchase the wiring, much less how to install it. Any guidance would be great!
Joel (<-- trying to get to Miller in a few weeks)
