CT-1 SwayBar
Old Nov 6, 2008 | 11:19 AM
mw9's Avatar
mw9
Default CT-1 SwayBar
Sam Straono(Stranoparts.com) now has Addco CT1( 1 3/8" solid) front bars in stock.The bar fits stock bushings and end links.
contact Sam at www.strano@stranoparts.com
They are going to be $115 shipped anywhere east of the Mississippi, and $125 shipped west of there (within the lower 48 states, way too big to try to ship to Canada or Hawaii for basically nothing.
Old Nov 6, 2008 | 04:19 PM
mw9's Avatar
mw9
bump, for a good guy and a good sway bar. Can help you out with all you suspension needs and driving help
Old Nov 6, 2008 | 04:39 PM
mw9's Avatar
mw9
http://www.stranoparts.com/partdetai...D=0&ModelID=24
Old Nov 7, 2008 | 06:50 PM
Gsedan35's Avatar
Gsedan35
Keep in mind that the CT-1 exist's because of Carter's desire to get the most front bar strength he could in the process of complying to SCCA class rules. IIRC, doing so benefited him by increasing rear grip under power. Otherwise outside of SCCA class rules you do not want to tie yourself into only one set bar setting, since sway bar's are really supposed to be used to fine tune the car's at the limit bahavior to your your specific setup and to your liking. In addition in the here and now, the CT-1 bar no longer can lay claim to the tittle as the stiffest avaliable for the platform, that now belongs to the H&R front bar which is 36mm solid vs the CT-1 (and Cusco) 35mm solid. And the H&R bar is adjustable.
Old Nov 7, 2008 | 10:04 PM
DmanG281's Avatar
DmanG281
The Ct-1 is adjustable.
Old Nov 7, 2008 | 10:48 PM
Gsedan35's Avatar
Gsedan35
That was the intent then Carter did the initial R&D, however what Addco ended up delivering didn't have that feature. Which is also why the Addco version that has been showing up on ebay for awhile now has the same specs and is also not adjustable. So, while the prototype was made adjustable, it's the only one that is.
Originally Posted by tomsn16
The CT-1 swaybar has been tested and the final design submitted.Specs are as follows:
1 3/8" solid
3 position lever arm
collars
Fits OEM mounts and links
Stiffness...compared to OEM '03 = 35,62,98 % stiffer
" OEM '04/'05 = 15,40,70% stiffer
position 1 for wet surface
position 2 for asphalt & low grip concrete
position 3 for high grip concrete
Jim & Carter Thompson
Quoted directly from the Stranono web site
"This bar is non-adjustable. It requires the use and slight modification to 350Z Track model front mount bushings (bored from 34mm to accomodate the appoximately 35mm diameter of this bar)."
[QUOTE=tomsn16;2523646]Saw Sam Straono(Stranoparts.com) this past weekend and he now has Addco CT1( 1 3/8" solid) front bars in stock.He has reduced the price because they were delivered with only one link hole.The good news is the hole is the soft setting one and that is the one we have found works best and what we used at the Peru(concrete) and DC(asphalt) Pros.The bar fits stock bushings and end links.
Jim and Carter T.
contact Sam at www.strano@stranoparts.com[/QUOTE
JUN14scr....please note that our setup is for autox only....doubt that it would work at all on the track.
ULLLOSE is on target re the Z's lack of front camber adjustment for stock class autocrossing. Our setup is for sure full of compensating adjustments to find the best compromize between understeer and rear wheel spin....the Z's LSD is also not what we would like it to be either....but you work with what you got or you get something else.
If the Cusco is solid then it is same as the CT1 with equal lever arm. When we had the proto type 1 3/8" (35mm) solid bar made there was nothing that big on the market and the Cusco at that time was a hollow bar.
Regarding our setup.....everything we have done has been directed at:
1.Reducing understeer
2.Reducing rear wheel spin
The big bar is just one part of the equation.
Old Nov 7, 2008 | 10:55 PM
DmanG281's Avatar
DmanG281
I bought mine from Jim and Carter directly. It was the bar that came off of their personal Z and I assure you it has three holes in it.
Old Nov 7, 2008 | 11:10 PM
Gsedan35's Avatar
Gsedan35
I edited my post because I accidently left out the quote where Carter talks about the prototype bar being adjustable. So having bought the prototype, yours is adjustable. But as my post above also confirm's, it's the only one of it 's kind.
Old Nov 8, 2008 | 03:58 PM
tomsn16's Avatar
tomsn16
If the CT1 from Strano has only one hole...just drill additional holes...should be easy.However you are likely to find the soft setting hole works best as we did.
Jim and Carter
Old Nov 10, 2008 | 08:19 AM
TractionCircle's Avatar
TractionCircle
I run the CT-1 bar from Strano on mine as well. Works great and half the price of other bars. No squeaking or clunking and really helps put the power down.
Note: If and when you break a front sway bar endlink, you will notice it immediately because you will get insurmoutable wheelspin. (Spotters said my inside rear wheel was over a foot off the ground!!!!)
Carter, When drilling the extra holes, will I need to flatten any more of the tubular part? Or is there enough room.
JR
Old Nov 10, 2008 | 08:35 AM
tomsn16's Avatar
tomsn16
Don't know how much flat length there is to work with on the final bar.On our prototype there was plenty of room for three holes. Our holes were approx 3/4" apart,centerline to centerline. The lever arm lengths were 8 9/16",7 13/16" and 7 1/16". Lever length measured from hole centerline to bar centerline(section of bar that goes through mounting bushing).
tomsn16
Mar 20, 2012 06:41 PM
Mr_Q
Jul 19, 2005 10:12 AM
jun14scr
Jun 16, 2005 08:23 PM
DavidM
Apr 22, 2005 08:17 PM
jreiter
Mar 22, 2005 11:58 AM
