The Tire DB - Posts about Track and AutoX tire brands
Old Oct 31, 2008 | 02:47 PM
  #541
Ataru074's Avatar
Ataru074
btw.. in the classified there is a guy selling 4 lmgt4 18*9.5 with toyo R888 with half life left... that could be a good deal for him.
Old Oct 31, 2008 | 08:36 PM
  #542
got556's Avatar
got556
Default 5Zigen FN01R-C 17X10 +25 and 332mm Stoptechs...will it work?
Okay guys...I'm about to send a guy the cash for some FN01R-C's. They're 17X10 +25 offset all the way around which I know is a pretty common setup here. My question is...I was planning to run Stoptech's 332mm front kit w/ the stock stage 2 kit in the rear, for now. Will the 332's and the rotors fit w/ this setup?
Thanks in advance.
Old Oct 31, 2008 | 10:40 PM
  #543
scotts300's Avatar
scotts300
I did the math and cutouts and it seems they will fit, so I bought a set as well. I know the 17" 5Zigen Pros fit, so I'm assuming the FN01R-Cs do.
Old Nov 1, 2008 | 01:26 AM
  #544
got556's Avatar
got556
Sounds good and thanks.
Old Nov 1, 2008 | 04:50 PM
  #545
scotts300's Avatar
scotts300
Which version (1 or 2) and which finish did you get? Mind me asking the price and what size tires are on them/you plan to put on them?
Old Nov 2, 2008 | 09:26 AM
  #546
six3mike's Avatar
six3mike
I have 18x8.5/9.5 FNO1RC's with a +38 offset and they fit fine. So you should be good to go. I have the 14" StopTech kit all around.
Old Nov 2, 2008 | 02:57 PM
  #547
35Z's Avatar
35Z
Thumbs up Sq
Originally Posted by betamotorsports
Fear of oversteer is a mistake. A balanced tire setup on a 350Z is the best way to get started on the track because you need to learn about oversteer (cornering limit oversteer, not stab the throttle oversteer). A balanced tire size setup works best for the above and it also lets you rotate the tires so they last longer. 245s all around is my suggestion and its something I've done when I first start running the 350Z.
Square setup
I have BFG KW 245-40/18f 24545/18r. It has been a good all-around balancing act while learning to track your Z (Note: The 350Z needs to "rotate" while cornering which I thinck he is referring to in betamotorsports post). You may want to swap out your sway bar/end-links with adjustable settings to suit your driving as your ladder-up in class. You likely toast the 35th Addition front calipers if you track your Z frequently. Rear calipers seem to last in my experiance.
Good luck and have fun!!
Old Nov 2, 2008 | 05:52 PM
  #548
PDX_Racer's Avatar
PDX_Racer
Originally Posted by mitchmo
can anyone show a picture of 285/30's on a 8" wheel. pref on the car
I'll see what I can dig up as far as front shot of my car.
Compared to a friend's RX-8 on 285/30R18s, even the front stock track wheels (18x8) lay down all (or most) 285 of the Kumho V710s, and they wear very evenly.
Old Nov 2, 2008 | 06:57 PM
  #549
z-u-later's Avatar
z-u-later
Originally Posted by BloMyS14
Enkei RPF-1
18x10.5 +15 Front
18x10.5 +0 Rear
Kumho V710 285/30/18 Front and Rear
Are these factory rim offsets? Just curious on the +0 in the rear. These are pretty aggressive offsets so I assume no spacers? Have you tracked this setup yet?
Old Nov 2, 2008 | 10:34 PM
  #550
phorbo007's Avatar
phorbo007
I just bought some RPF1s 18x10.5 +15. I'm pretty sure Enkei does not make a +0 for this model, unless he got a custom set.
I would think he's running 15mm spacers in the rears. Can someone confirm?
Old Nov 3, 2008 | 03:57 AM
  #551
Beau's Avatar
Beau
What is your camber front and rear?
Old Nov 3, 2008 | 04:24 AM
  #552
z-u-later's Avatar
z-u-later
Hey, I'm looking at the RPF1s also with the +15mm offsets. Did you go the same size -- front & rear? Just curious what size tires you mounted.
Old Nov 3, 2008 | 04:28 AM
  #553
z-u-later's Avatar
z-u-later
These rims are Brembo-friendly, correct? I'm also looking at these, along with the RPF1s.
Old Nov 3, 2008 | 09:16 AM
  #554
six3mike's Avatar
six3mike
I dont think you'll have an issue.
Old Nov 3, 2008 | 09:56 AM
  #555
got556's Avatar
got556
Thanks guys...
Scotts, I'm not sure the difference between ver1 and ver2 but I have the high disc ones with the concave. Here's a pic of the ones I'm getting.
Old Nov 3, 2008 | 10:37 AM
  #556
scotts300's Avatar
scotts300
Are you using spacers? I know you don't HAVE to, but that offset is not the best of the choices for a Z33.
Old Nov 3, 2008 | 10:38 AM
  #557
scotts300's Avatar
scotts300
Originally Posted by got556
Thanks guys...
Looks like V1, which is what I have also. Are those 275/40/17 V710s?
Old Nov 3, 2008 | 11:38 AM
  #558
phorbo007's Avatar
phorbo007
The RPF1s I got are 18x9.5 +15 F and 18x10.5 +15 R and I ordered Falken 452s 245/40/18 F and 275/40/18 R. Waiting for the tires to come so I can get them mounted on. I'm only going to be tracking my car 2-3 times a year at most so I opted for the typical staggered setup.
Old Nov 3, 2008 | 12:30 PM
  #559
z-u-later's Avatar
z-u-later
^ Why 452s instead of the 615s?
Old Nov 3, 2008 | 02:39 PM
  #560
mitchmo's Avatar
mitchmo
thanks alot PDX seeing is believing you know
