REQ: Recommendations on all fluids/oils for a Trackday car.
Old Sep 12, 2010 | 08:21 AM
SIR_pierre's Avatar
SIR_pierre
Default REQ: Recommendations on all fluids/oils for a Trackday car.
For every year that goes i use my car more and more for only trackdays, And driving to and from them.
At my last trackday my oil temp went up to 145c!
So now its time to change the fluids and i was thinking of replacing them for more racing friendly ditos.
I have a 2004 with Greddy TT
so what oil/fluid should i use/are the best for
Transmission
LSD diff
Power steering
brakes
So far i have used
Tranny = Redline MT-90
Engine = Shell
LSD = Redline HP GL-5 75W-90 LS
Brakes = Shell DOT 5.1
Powersteering = Shell something..
The last 3 years i have done my sevices at Ferrari, So i have used their oils.
But i dont think thats good enough enymore.
The full spec on the car is here
http://www.garaget.org/?car=40534
And keep in mind, They oil temp goes up fast on the track and the car is ALWAYS driven hard
Old Sep 15, 2010 | 04:51 AM
SIR_pierre's Avatar
SIR_pierre
Nothing???
Old Sep 15, 2010 | 05:05 AM
JasonZ-YA's Avatar
JasonZ-YA
LSD diff = Motul 90PA
Power steering - dont remember, but with a larger ps cooler your golden with whatever shell fluid you have.....:See here:
brakes = Motul RBF600
-J
Old Sep 15, 2010 | 07:31 AM
SIR_pierre's Avatar
SIR_pierre
Motul, Ill look in to that .
I havent actually had problems with the steering,. i just want the best there aswell =)
Old Sep 15, 2010 | 07:33 AM
halfrice's Avatar
halfrice
Tranny = Motul Gear Oil
Engine = Motul
LSD = Motul 90PA
Brakes = Motul RBF600
Powersteering = Redline PS Fluid
Planning on switching engine/trans/lsd to torco this month.
Old Sep 15, 2010 | 07:54 AM
SIR_pierre's Avatar
SIR_pierre
Why is Motul the best?
And about the engine oil,,, what numbers should i look after,, i dont know what all the 10-60/15-40 etc etc means.
Old Sep 15, 2010 | 08:00 AM
betamotorsports's Avatar
betamotorsports
Any full synthetic oil (Mobil 1, Redline, Motul, Castrol, Torco, etc.) will be fine. I would run the gear and engine oil weights specified in your owner's manual. Also, remember to use a GL5 gear oil for the diff and a GL4 gear oil for the transmission. Nissan transmissions traditionally do not like a GL5 gear oil.
Old Sep 15, 2010 | 08:09 AM
SIR_pierre's Avatar
SIR_pierre
yes that part of GL4 and GL5 i have read in the manual.
so even if i dont use the cas as it was built for im still going with the 10w-40?
Old Sep 15, 2010 | 08:19 AM
betamotorsports
Yes. Until you actually do some analysis you should stick with what the factory recommends. I suggest that you start sending out oil samples for analysis and that will give you some direction regarding viscosity, contamination, engine condition, and oil change intervals. Just guessing or relying on Internet Engineering can get expensive.
Old Sep 15, 2010 | 08:24 AM
SIR_pierre's Avatar
SIR_pierre
yes that would be the best,
but i have no idea where to get that kind of info here in sweden,
there is a whole thread here about what oil to use with turbos
https://my350z.com/forum/engine-and-...d-info-50.html.
50 pages and no conclusion =)
Old Sep 15, 2010 | 09:19 AM
Zazz93's Avatar
Zazz93
I would agree with John on getting an analysis to further your choices. And watch out for the GL5 oils in the tranny, some manufacters say that oil actually eats up the brass in the tranny. I think Royal Purple has a few choices for good GL4 friendly oil in their lineup vs. most companies only offerring a 75-90'ish viscosity for the GL4's.
Old Sep 15, 2010 | 09:32 AM
betamotorsports
Search on Swedish industrial and machinery web sites. Or search for "Oil Analysis".
And why would you expect a whole bunch of Internet Engineers to come to a conclusion?
Old Sep 15, 2010 | 11:21 AM
SIR_pierre's Avatar
SIR_pierre
Perhaps a few of them have done a analys or works with oil? =)
I´m just a driver =)
AbrasiveRaysive
Sep 20, 2021 02:29 PM
apex locator
Jul 23, 2021 02:27 AM
May 30, 2017 03:28 PM
Mattg350z
Oct 2, 2015 06:51 AM
