Nissan FINALLY has a 350Z brake duct!
Old Jun 26, 2013 | 01:28 PM
  #221
GrandAm350's Avatar
GrandAm350
They are no longer made.
Molds have been mothballed.
Nissan Motorsports my have some sets left, but doubt it. You might want to try them.
Old Oct 19, 2013 | 05:02 AM
  #222
crZydave's Avatar
crZydave
Bringing this thread back from the dead. I did my own ducting recently. Here are a few pics. I reused the holes in the bumper for the little plastic pieces that used to go in the corners of the front grill to mount the brackets. I also had to remove the washer fluid reservoir so I could get the tubing routed to the wheel on the right side of the car.
Old Oct 19, 2013 | 07:51 AM
  #223
terrasmak's Avatar
Please post how you hooked up to the spindle/caliper.
Old Oct 19, 2013 | 07:52 AM
  #224
SE5spd's Avatar
SE5spd
Interesting way of doing it, mine was similar.
Old Oct 19, 2013 | 12:00 PM
  #225
N80's Avatar
N80
That's what I'd like to see too.
Old Oct 20, 2013 | 05:35 AM
  #226
crZydave's Avatar
crZydave
It's by no means the best setup. I didn't do anything fancy with the connection to the spindle/caliper. I can't remember the thickness of flat bar I used (I used two different thicknesses), but it was aluminum and about 1 inch wide. I used a thinner flat bar and rolled it into an ellipse (still fairly round but I tried) with a diameter slightly larger than the tubing. Then I slid it inside the tubing and used it like a spring to hold it in place. I had a large washer and bolt with a locknut to keep it from sliding off the tubing and used it to mount to the L bracket I made. The L bracket was made with a little thicker flat bar and mounted to the lower Stoptech caliper bolt. That's it.
There wasn't much open space to get inside the rotor with the Stoptechs. I might have to go back and redesign it at some point, but I wanted to try this first. If the rotors stop getting the micro cracks, and I get extended pad and rotor life, then I'm not changing anything.
I didn't have any issues with it after my first event with them on. I need to get some new rotors to see if they are working, but I'll wait till these are dead since Stoptech charges a sh!tload for replacement rings.
Old Oct 25, 2013 | 03:55 PM
  #227
dnguyent's Avatar
dnguyent
I bought a set of these CF brake cooling kits from Trakhaus years ago. I sidelined my track days by having another kid. In any case, they are sitting on a shelf in my garage, and have never been installed. I don't think I'll ever get around to install them, let alone squeeze in another track day for the next few years. They were $300. If anyone is interested in buying the set, please PM me.
Old Oct 25, 2013 | 04:25 PM
  #228
isy_nismo's Avatar
isy_nismo
You have a pm. Thanks!!
Old Oct 25, 2013 | 07:43 PM
  #229
terrasmak's Avatar
I doubt you can keep then cool enought to stop micro cracks.
Old Oct 27, 2013 | 07:38 PM
  #230
crZydave's Avatar
crZydave
You very well may be right. The only point of reference I have is my buddy that tracked his C6 Z06. He did basically the same thing and it greatly helped his rotor life. It didn't stop the micro cracks, but it helped.
All I really want is to be able to wear down the rotor to its min thickness before it cracks in half. I got about 1/2 through the last set of rotors before all the micro cracks connected and I had complete rotor failure.
What are you thinking needs to be done? Seal it off so all the air gets inside the center of the rotor? (BTW, I'm not trying to sound like a *****, I really wanna know)
BTW, I don't even know for sure if there is even any air making it to the rotor.
Old Nov 5, 2013 | 04:15 PM
  #231
randyzimmer's Avatar
randyzimmer
Default Something New
Something I whipped up...
Old Nov 5, 2013 | 07:38 PM
  #232
sidewaysil80's Avatar
sidewaysil80
Would you be willing to make a set without the fan? Im looking for something similar to the trakhaus carbon ones that focuses air into the rotors center...but I cant justify $300 for theirs. I don't have the time/skills to make something and would gladly pay for such a product if it didn't carry an inflated price tag.
Old Nov 5, 2013 | 08:06 PM
  #233
terrasmak's Avatar
That has a brushless motor and it's an EDF unit. That will push a crap ton of air.
Old Nov 5, 2013 | 09:45 PM
  #234
sidewaysil80
As of now are there any options that mount to the spindle with just a simple flange?
Old Nov 5, 2013 | 09:56 PM
  #235
terrasmak's Avatar
Not that I know of, but I'm going to just rivet http://www.aircraftspruce.com/catalo...uctflanges.php onto the heat shield.
Old Nov 6, 2013 | 04:33 AM
  #236
sidewaysil80
Thats def. an option. The PO removed the front dust shields on mine, it obviously wouldn't be hard to put them back and go that route, but I just learned of the trackhaus ones and love the design...just not the price. I wonder how one could replicate them, maybe with a different material; tin or aluminum perhaps.
Old Nov 6, 2013 | 08:56 AM
  #237
sfarrah's Avatar
sfarrah
what cfm do they flow? much of a power draw?
Old Nov 6, 2013 | 09:00 AM
  #238
randyzimmer
Hi Sideways,
I could make a pair with the size inlet you want for $150.
I'll give you the drill, tap, allen and buttonheads too.
(but the fans are the way to go)
The aluminum taps very easily, just a little light oil on the tools.
Old Nov 6, 2013 | 10:21 AM
  #239
randyzimmer
I haven't measured the flow, I can program from 1 to 27.5A(each!)
I think 10A is the sweet spot, good volume, lower noise level, reasonable wiring and draw.
Here's an old test I did, be sure to tun down the sound. You'll see the turning duct get pushed off as the revs come up to the full 27A speed:
I had a message the video didn't exist when I tested it, go to You Tube and search:
prototype RooDuct fan duct test
Last edited by randyzimmer; Nov 6, 2013 at 10:30 AM. Reason: added turn down the sound, it's loud!
Old Nov 7, 2013 | 08:42 AM
  #240
Blurvision's Avatar
Blurvision
It would be killer to have the variable amp fan hooked up to a temp sensor, gets faster as the rotor get hot.
