New NASA Class for 2012: Spec Z
Old Mar 11, 2012 | 10:05 PM
  #401
scotts300's Avatar
scotts300
Did my first event with the Spec shocks and springs (sway bars are on back order?). Lots of oversteer, I didn't like it. Lots of work to dial it all in. One more track day before the first SpecZ event.
Old Mar 11, 2012 | 10:50 PM
  #402
Fixxxercask's Avatar
Fixxxercask
Hmmm...interesting. How long on the sways?
Old Mar 11, 2012 | 11:06 PM
  #403
ChargedZ's Avatar
ChargedZ
Did you use a square wheel setup?
Old Mar 12, 2012 | 03:50 AM
  #404
laze1's Avatar
laze1
GAAAA!!!!!!!!!!! Don't tell me that...bad handling AND back-order on parts
Old Mar 12, 2012 | 03:53 AM
  #405
mhoward1's Avatar
mhoward1
Where was the oversteer, neutral throttle or applied throttle?
Old Mar 12, 2012 | 07:24 AM
  #406
scotts300's Avatar
scotts300
No idea.
I did.
I know!
I should have clarified. It was on applied throttle, track out. These are turns I'm very familiar with, and used to be able to power out of with the last set-up. The rear springs are WAY stiffer than what I'm used to, so maybe that's part of it.
Has anyone else seen the set-up? There is a mini spring with the kit, a "helper" spring, I believe they call it. When this helper spring is installed and the ride height is minimized, that minimum height was about as high as stock in the rear. We took out the helper spring and were able to lower the car to what I'm used to (low 25s front, high 25s rear). The shop said the install was pretty straight forward otherwise, but we were back-and-forth with this mini spring.
I'm going to drive another event on 4/6 to try and dial it all in - hopefully the sways (that I've paid for) will be in by then. Ideas to counter the o/s? Loosen rear sways, reduce compression setting on shocks, etc.?
Old Mar 12, 2012 | 07:31 AM
  #407
mhoward1's Avatar
mhoward1
I'd losen things up a bit. How many settings do the sways have? Maybe dial in under steer then tighten things back up to your liking.
Do you think the LSD was causing 1 wheel spins?
Old Mar 12, 2012 | 07:48 AM
  #408
scotts300's Avatar
scotts300
The current sways have 3-settings, I don't know what the SpecZ sways have though. It still has the NISMO diff, and it's tight. The car handled superbly two weekends ago with everything the same minus the KWs instead of the Motons.
Old Mar 12, 2012 | 08:57 AM
  #409
mhoward1's Avatar
mhoward1
This is good info, keep us informed as you go.
Thanks
Old Mar 12, 2012 | 10:25 AM
  #410
scotts300's Avatar
scotts300
Thanks
Will do.
Wavetrak going in this week, and hopefully the sways arrive and those go in as well. I also hope that any rule adjustments are released soon - especially if there is an allowance for control arms, as the car is only at 2 degrees of camber in the front right now, and daddy likes a bit more than that.
Old Mar 12, 2012 | 10:56 AM
  #411
Fixxxercask
Thanks for the heads up Scott. Looking forward to hearing how the Wavetrac does.
Old Mar 12, 2012 | 12:05 PM
  #412
idrive_MD's Avatar
idrive_MD
Great update Scott...was there any room to get more front camber with a lower ride height that wasn't damaging?
Old Mar 12, 2012 | 02:36 PM
  #413
scotts300's Avatar
scotts300
Yeah, it could probably go lower in the front, but I wanted to keep the rake in check since the rear is almost bottomed out.
Old Mar 13, 2012 | 12:07 AM
  #414
ldstang50's Avatar
ldstang50
Scott
If the sways come in and assuming the front bar is stiffer than your current try running the new bar on full stiff. If you're doing one tire fires on corner exit this should help. If that helps Or doesn't help then try running the rear at full soft
You were running the r1s? Were the scrubs or a brand new set? What was your tire wear like?
Old Mar 13, 2012 | 08:05 AM
  #415
scotts300's Avatar
scotts300
Originally Posted by ldstang50
Scott
Supposedly, I have the NISMO sways on the car now. They are discontinued, so I couldn't easily confirm that's what they were. I'll do as you suggest when the Spec sways come in - thanks. No, I was on V710s. I ran them with SCCA two weekends earlier, and they were great. Tire wear in the rear was not great, so I put that tire up front on the inside.
Off topic - has anyone found/ordered the "Lug nut Spec Motorsport open end (20 needed) 40222-SS000"?
I can't find them anywhere, and am just trying to live by the letter of the law.
Old Mar 14, 2012 | 08:33 AM
  #416
racerbob4's Avatar
racerbob4
I am pretty sure we get our open end lug nuts from Summit Racing in Ohio where we also get our ARP wheel studs.
Old Mar 14, 2012 | 08:49 AM
  #417
scotts300's Avatar
scotts300
Neither of those are legal for the class is my problem. I found/ordered the NISMO studs, but can't find the spec lug nut. Seems silly, I know, but if I'm building spec I am building spec.
Old Mar 14, 2012 | 09:23 AM
  #418
DivZero's Avatar
DivZero
Have you called Nissan USA? Phone number on page one of the catalog here:
http://www.nissanusa.com/nismo-web/N...talog-2010.pdf
I'm curious Scott (trying to learn), did you lower the rear pressures at all to try and counteract the oversteer? If not, why?
Old Mar 14, 2012 | 09:33 AM
  #419
Neimad's Avatar
Neimad
Wheel and Tires
16.1 Wheels
a) Any eighteen (18.00) inch diameter rim, with a maximum width of nine (9.00) inches front, and a
maximum width of ten (10.00) inches rear may be used.
b) No wheel permitted for competition use can weigh less than eighteen point five (18.50) pounds.
c) Wheels must be one piece. (i.e. No multi piece bolted, riveted, or welded wheels.)
d) Aftermarket wheel studs, lug nuts, and wheel spacers are permitted. If spacers are used they
shall be no greater than 13mm and equal per axle. Refer to Appendix A for recommended Niss
Old Mar 14, 2012 | 09:49 AM
  #420
scotts300's Avatar
scotts300
I'll call them - thanks.
I did lower the tire pressures. I'm pretty "dialed in" with tire pressures based on my old set-up, but it was still really touchy.
Originally Posted by Neimad
Wheel and Tires
16.1 Wheels
Agreed. Here is Appendix A:
Wheel
Wheel stud Spec: NISMO 60mm (2 needed) 40222-RS045
Lug nut Spec: Motorsport open end (20 needed) 40222-SS000
Only question is how to determine "recommended".
