New NASA Class for 2012: Spec Z
I have 6 new tires, and I think mine are all late 2011...I will check this weekend.
Who did you get them from? Mine came from Jackson marketing
Nissan Sport magazine will have a DIY tech article on the BFG R1 in the upcoming issue. Without giving anything away, tires produced in mid-year 2010 should be just fine as long as they've been properly stored.
SpecZ issue #2, page 56: http://www.snmagcurrent.com/publication/?i=114117
As someone who has first hand experience, go with 20 mm spacers. There's just not that much caliper clearence without that size spacer on a 9.0 X 18.0" RPF1.
I suppose the 4th number is the date code...if it is, here are my dates
4710 and 4810 mixed across the sets of 6
Note: One side of the tire has 3 numbers. flip the tire and it has 4 numbers..wierd
that shows 5F11...
My car is not back from the clutch/tranny swap...but going with a 20MM is likley the way to go...that is what I plan to run
Note: Z1 Motorsports has some good prices...tell Shanna I sent you...(sucking up for sponsorship)
http://www.z1motorsports.com/350_g35...oducts_id=3118
1 x CNC Aluminum Hub Centric Wheel Spacers 2.5, 5, 10, 15, & 20mm) = $44.00
Thickness 20 mm
Sub-Total: $44.00
FedEx (Ground Home Delivery): $9.20
GA Tax: $3.08
Total: $56.28
Thickness 20 mm
Sub-Total: $44.00
GA Tax: $3.08
Total: $56.28
Either 3MM or 5MM...I have 2 of each for you to try out....5MM is what I used. Note: 5MM is the Max limit of what you should use with stock length lugs....so we should test fit the 3MM.
I will be there Friday doing Test and Tune if you wanna swing by...then
Z1 Motorsports sells them pretty cheap....
Thickness 20 mm
Sub-Total: $44.00
GA Tax: $3.08
Total: $56.28
Thickness 20 mm
Sub-Total: $44.00
GA Tax: $3.08
Total: $56.28
John...I'll stop by Fri afternoon (i haven't checked the schedule yet) for test fit, settle up and pick up on Sat...I'll work around your schedule...i can maybe stay and lend a hand or encouragement as needed, but new to the Z platform...i have a few (read: a lot) of questions
see ya this weekend
see ya this weekend
